586,531 active members*
2,875 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > crashed my lathe, power feed wont come back on
    Jun 2010
    1414
    Lathe power up. Its a Grizzly G0750g 12x36 gunsmithing lathe. https://cdn0.grizzly.com/manuals/g0750g_m.pdf
    I just figured out how to push that blue dial on the right in, give it a quarter turn and it locks in, but that red button wont stay in. No idea what to do.
    Jun 2010
    1414
    Re: crashed my lathe, power feed wont come back on
    I should mention that the lathe does power on... but the power feed button doesnt.
    Dec 2013
    5717
    Did you check the fuses?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2010
    1414
    the fuses were fine. they would have lit up if they were bad.
    figured out the problem. KA0 needed to be reset. I didnt even know you could do anything with these things. Called tech support and they talked me through the problems. The cover comes off, and I touched it slightly and it fell back into place like a GFI contact and it fired back up. I knew it was something simple. Hopefully if someone else has this problem after a crash, they find this thread.
  1. Replies: 1
    Last Post: 09-21-2013, 12:40 AM
  2. 9x20 HF Lathe Power Feed Issue
    By jroberts1968 in forum Mini Lathe
    Last Post: 07-06-2011, 02:37 PM
  3. BP Power down feed leaver jumps back
    By CNC OT in forum Bridgeport / Hardinge Mills
    Last Post: 11-25-2007, 12:32 AM
  4. lathe + power feed + measure + z
    By deji in forum MetalWork Discussion
    Last Post: 05-15-2007, 04:26 PM
  5. Lathe work feed back
    By Kool Parts in forum RFQ Feedback
    Last Post: 09-27-2006, 02:30 PM
