586,761 active members*
7,197 visitors online*
    May 2007
    Trouble importing DXF files from autocad to Mach2
    I am generating 2D drawings using autoCad 2004, and saving the file as '.DXF'. Using Mach2Mill, I import the DXF drawing and generate the Gcode. The display (in Mach2) shows the drawn item correctly if it is a square, or a circle. The milled item (square or circle) is correct. If I draw an object such as a semi-circle with a straight line joining the ends of the semi-cicle, the graphic shown in Mach2 is incorrect and the milled shape is completely wrong. Within autoCAd 2004, there are 3 versions of DXF file that the drawing can be saved as, and I have tried all 3 with the same result. Thanks for any help.
    Post the problem .dxf
    213
    I also am trying to figure out Mach 2 and was going along fine until I punched something inadvertently now everything is in french and I cannot find a way to get the screen back to english . Any help appreciated ... mjh
    Try View>Load screens and choose 1024.set when the file dialog opens. If the menu's are in French, View is the 4th menu from the left and Loas=d Screens is the first menu item.
    213
    thanks very much
  1. Importing dwg.files
    By wsteve in forum Rhino 3D
    Last Post: 05-09-2007, 08:51 AM
  2. About Importing Files
    By Gorillakilla in forum Mach Software (ArtSoft software)
    Last Post: 04-11-2006, 10:37 PM
  3. Importing files to turbocnc
    By mikburts in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2005, 12:35 AM
  4. importing 3d iges files
    By jallen in forum BobCad-Cam
    Last Post: 07-07-2005, 02:35 PM
  5. importing files to machine
    By fastolds in forum GibbsCAM
    Last Post: 06-23-2005, 01:48 PM
