587,058 active members*
3,693 visitors online*
Results 1 to 2 of 2
    Mar 2016
    1
    I need help, thc robot3t01 up & down
    good afternoon, first of all I apologize for my bad English. I recently finished my cnc for plasma and I bought a thc robot3t with outputs up and down. I'm not familiar with thc and I do not know how it works. In theory it must work by measuring the tension of the arc and correcting based on the setpoint that it places. The problem is that I am not very clear about the function of the thc parameters. Would someone be so kind to help me adjust the thc? I have all the wiring placed, the correct configuration in mach3 but the thc does not regulate the height of the torch as it should. Thank you
    Jul 2005
    2415
    Re: I need help, thc robot3t01 up & down
    It has to be paired with control software and hardware that can use the UP and DOWN to control the Z axis motor. MACH3 is one example. I think UCNC is another.
