586,721 active members*
3,322 visitors online*
Thread: HAAS MDI
    Jan 2014
    32
    HAAS MDI
    Curious as to how others use MDI on a HAAS. I just recently purchased a HAAS VF2SS and not used the MDI not deleting after code is executed.
    I use it for short basic codes, calling up edge finder and turning on spindle, changing tools, load position, double checking home coordinate location, etc.
    Is there a way to have it delete after the program is executed or does anyone leave some basic everyday used codes in MDI with a code to separate commands.
    Nov 2007
    479
    Re: HAAS MDI
    in mdi, hit erase program to delete whats stored there.
    Apr 2005
    713
    Re: HAAS MDI
    Quote Originally Posted by bthomas7408 View Post
    To change tools without MDI: In any mode except memory, type T1 and hit ATC FWD - you get T1 in the spindle. Or type P1 and hit ATC FWD - you get whatever tool is in pocket 1 in the spindle.
    To start spindle without MDI: In any mode except memory, type 1000 and hit SPINDLE FWD. Beware, if you just hit SPINDLE FWD at any time without typing an RPM, it will turn on at whatever the last commanded RPM was.
    63
    Re: HAAS MDI
    I use MDI to run one line of code at a time. Common ones I don't erase but I put a mandatory stop, M0, on the next line. This way I can have about 4 one liners at a time in the MDI and I just cursor down to the one I want to use, and hit the reset button when I'm done. So my MDI may look something like...
    M3 S3000
    M0
    G0 G54 G90 X0.0 Y0.0
    M0
    G0 G59 G90 X1.0 Y-3.0
    M0
    [email protected]
    http://www.xenomechanics.com
  1. HAAS HA5C on Matusra RA2F - Issues with 2 different HAAS Rotarys/Indexers
    By bjstratton84 in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2016, 04:08 AM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
