587,043 active members*
3,052 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS DS30-SSY with M97 Looping
Results 1 to 8 of 8
    Jun 2014
    52
    Good afternoon,
    I am having a couple head scratchers with my DS30-SSY while attempting to run out a Macro Program I have made. The first thing I am curious about is when I press stop at any point in time and resume into the program I lose the loop counter. Does anyone know of a way to maybe manipulate this? The real problem occurs when an operator stops the program and starts the program again from the start. This resets the counter again at the value listed at the beginning of my code. I will post this code and would love to hear what anyone may think could be a quick fix here.
    My second concern isn’t really with the DS30-SSY it more so falls on the programming software side of things however I am sure you can manipulate the Haas to run it how I am thinking. I am using an inserted drill to blast through the center of my part and coming back with that same drill to turn the ID to size. How would I go about offsetting my tool? The first OP wants to use the tool centerline and the second wants to use the corner. My thought was that I could change the actual X dimension in the code so that it is no longer cutting on X0. I am unsure if that is the best way to cheat your machine though. If anyone else has a good idea for this please let me know! Anything is greatly appreciated, thanks ahead of time!
    Here is the start to my code where I am using M97:
    O12345
    M97 P1 L45 (Call sub-program O0100 – repeat subprogram 45 times)
    M30
    G20
    (TOOL - 3 OFFSET - 3)
    (DCLNL 12 4B INSERT - CNMG 12 04 08-PM)
    N1 T0303
    "The one who follows the crowd will usually go no further than the crowd..."
    -Albert E.
    Nov 2007
    479
    Re: HAAS DS30-SSY with M97 Looping
    Set the Insert that is cutting the bore into another tool offset. Then call the tool with corresponding offset you set the tool to in the program.
    Jun 2014
    52
    Facepalm. I should have known that; much appreciation! Do you have any experience with the M97 and looping command? I am running a full bar at a time and producing 47 parts per bar; I just want to be able to stop the program and maintain its current loop count, but I do not know if that is something that is an option. Thanks again for the explanation on that offset tool set-up. With some things involving lathe CNC centers I am still green and mostly self taught so I appreciate that information!
    -Albert E.
    Feb 2011
    353
    I would think that within the loop you set a counter
    #500=0
    #501=45
    M97 P1 L[45-#100] (Call sub-program O0100 – repeat subprogram 45 times)
    N1 T0303
    #500=#500+1
    M99
    Jun 2014
    52
    Quote Originally Posted by rcs60 View Post
    That's a really good idea, I could get away with that and put it directly at the top to act the same as the loop call-out and still be functional after an insert change or machine stop then I could have the counter wiped in the code after it sees my M30. Excellent idea! I will give this a try and see what I come up with, I appreciate that a ton!
    -Albert E.
    Feb 2011
    353
    if the M98PxxxxL[45-#501] Doesn't work
    you could try this
    N1(SET COUNTER)
    #500=0
    #501=45
    N2
    IF[#500GE#501]GOTO3
    M98PxxxxL1
    #500=#500+1
    GOTO2
    N3
    M30
    THE #500 WOULD RETAIN THE VALUE IF THE CONTROL WAS TURNED OF OR RESET
    BUT WOULD HAVE TO BE RESTARTED ON N2
    Jun 2014
    52
    Thanks that actually worked excellently! I have it running and the Macro keeps track of it now. Thank you very much for the help on this! I apologize it took me so long to get back to you but I had to wait until I saw the parts again. Worked like a charm though!
    -Albert E.
    Feb 2011
    353
    you are welcome and i am glad it works for you
  1. HAAS DS30-SSY with M97 Looping
    By Cshade30 in forum Haas Mills
    Last Post: 01-17-2019, 01:32 PM
  2. Replies: 2
    Last Post: 12-07-2017, 06:15 PM
  3. Haas DS30 Y lathe 2014, X Axis drift
    By Hammer-On in forum Haas Lathes
    Last Post: 09-24-2016, 10:04 PM
  4. looping
    By dinglekiller in forum G-Code Programing
    Last Post: 02-01-2012, 05:47 AM
  5. HAAS DS30-SSY DUAL SPINDLE
    By WORKALONE in forum Haas Mills
    Last Post: 10-12-2011, 07:55 PM
