586,983 active members*
3,954 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > acramatic 2100 load problem
Results 1 to 19 of 19
    Dec 2018
    15
    i have Cincinnati CNC turning machine with Seimens Acramatic 2100 when NT system loading it appear screen with many message as attached and not open how can i solve that
    Dec 2006
    585
    Re: acramatic 2100 load problem
    Dec 2018
    15
    photo in attached
    Dec 2018
    15
    please check
    Mar 2011
    464
    That typically happens with a corrupted hard drive, but could be WS board or bad connection to hard drive.
    Dec 2018
    15
    hard disk was have bad sector i take backup from it and put it in another hard disk but still have same problem
    Dec 2006
    585
    Sounds like you just made a backup copy of a bad hard disk drive and the backup drive would also be bad. It is the software that is BAD.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2018
    15
    are there way to fix software?
    Mar 2011
    464
    Depending on where the issue is in the file system, I have known some shops able to fix this themselves by repairing Windows, but you would need the proper Windows NT repair disc to attempt this.
    I have been able to successfully repair most of the hard drives sent to me as long as it is software corruption and not a mechanical failure, but I have several hard drive utilities and working versions of the Acramatic software that allow me to rebuild the various layers that may be damaged.
    Since you do not have access to this, your best option would be send it out for repair, or to contact Cincinnati and purchase a replacement hard drive for the machine.
    Dec 2018
    15
    Windows NT repair disc is that 3 disk i have it can you give me step for it when i use it request windows nt cd or source and i not have cd room in machine and not found source for NT windows
    Mar 2011
    464
    I can't walk you through this procedure as I don't know your ability level, what hardware you have access to, or even what software version you have/need (the machines did not come with software to recover from this). I was only letting you know if the corruption is in the Windows section of the hard drive, I have seen some customers successfully address this with Windows Repair discs (they had access to through IT personnel). I do not know what is corrupted on your hard drive, so can't say this will fix it for you.
    Dec 2018
    15
    the problem is in windows file on hard disk and i try repair it with windows repair disk but it not accept and if i try install new NT acramtic software not open , only the nt open as PC
    Mar 2011
    464
    Based on your reply I'm not sure whether you are saying you have the NT repair software needed or not. If you don't have the NT repair disc specific to the version of Windows on your hard drive, this won't work for you. If you do have it, you will need to follow the repair process. I do not use this method to repair the hard drives, so can't give you more details than that.
    Dec 2018
    15
    i download repair kit from internet and do all step but it fail to repair windows , so i can try to install new windows but need acrametic software source are you know from where i can get it
    Dec 2006
    585
    You should contact FIVES machine company 800-934-0735 and order a new upgraded SSD drive for your machine.
    Mar 2011
    464
    If the repair disc didn't work, then as I suggested earlier, your best options are to send the drive out to be repaired or to purchase a replacement. I only know of a few companies that can reliably repair the software on these, and depending on what you have done in attempting to restore this yourself, the repair option may be limited without just overwriting everything on the drive.
    And to answer your question specifically about where to get the software, the only place to purchase the Acramatic software would be Siemens for the Base and NCX layers and Cincinnati for the MAI. I don't believe either of them will sell the software for a field installation though so it is likely they would require you to send the hard drive to them for repair.
    Mar 2018
    9
    Hi, if the problem stays pls write to me (skype: kumanov16), I'll send you image with NT + Acramatic and explain you how to fix the problem. What is the machine?
    Dec 2018
    15
    ok i added u, it hawk150 cnc lathe
    Quote Originally Posted by ahkoura View Post
    Hi. Did you solve the problem with you mashine?
