586,551 active members*
3,368 visitors online*
    Dec 2018
    Help with probing routine
    Hi All,
    I'm using a Haas mini mill with a Renishaw probe and a second generation controller that I'd like to use to check for the width of a part and adjust the toolpath to cut a channel down the center no matter the part width. The parts are composites and coming out of molds so they vary in width by a small amount. I am fairly new to using probe routines and so far I've only been able to maneuver the probe to whatever position is needed using the protected moves and controller built in functions etc. I'm not sure if there is a built in routine that will do the correct action I'm looking for so I was looking for some insight. I need the probe to come down touch one side, then go over to the other side, touch off, grab those values and use them somehow to cut the channel down the center of the part. Thanks in advance everyone and Happy New Year.
    Oct 2007
    31
    Re: Help with probing routine
    second page of selections you can probe a lenght to get center in x or y . they need to be fairly close to the same lenght. just add it to the program.
  1. Probing Routine - Haas/Renishaw
    By amphib in forum G-Code Programing
    Last Post: 04-28-2018, 01:35 PM
  2. Fast Probing Routine/Wizard/Setup?
    By Bob La Londe in forum Digitizing and Laser Digitizing
    Last Post: 06-30-2013, 05:14 AM
  3. Heidenhain Probing Routine
    By nigel2000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2012, 01:50 PM
  4. A better JOG routine
    By Karl_T in forum CamSoft Products
    Last Post: 04-01-2011, 01:59 AM
  5. Sub Routine
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 09-18-2009, 01:01 PM
