587,250 active members*
3,574 visitors online*
Results 1 to 2 of 2
    Nov 2009
    75
    Fanuc 10TE-F MST code lock
    Hi everyone,
    Machine is Nakamura tome slant turn-2 with FANUC 10TE-F + FAPT programming
    Machine power on, operate manually and zero point is ok, manually turret +spindle + tailstock etc.... all working ,
    In auto mode program also running (machine is start ready condition) and all g command operated, but nothing happened when M-S-T code lines executed
    M3 S500---nothing
    T0101---nothing
    M8-----Nothing
    There are similar issue of forum, they were find Aux function lock on switch, but there is no this switch on our machine, we found menu switch option on setting menu, there are aux function lock also off status
    There is only M0-M1-M2 and M30 working with MFIN signal
    We dont have this system adress signal list, such as G-F signal list,
    Any idea highly appreciated
    Jan 2014
    106
    Check G44.1 for all axes lock.MLK in ladder.
    Or G108 for each axes lock. I am not familiar with this controller. Fanuc 10. But maybe it's close to the same as the newer ones.
    But if you can manually move the axes it may not be this..
    Well anything could be holding up the M8.
    But check G70.4-G70.5 for spindle CW CCW. (M3, M4)
  1. FANUC 10TE RAM problem
    By guhl in forum Fanuc
    Last Post: 12-20-2019, 05:41 PM
  2. Fanuc 10TE-F manuals
    By Eagleeye in forum Community Club House
    Last Post: 03-17-2012, 08:25 AM
  3. Fanuc 10TE-F
    By NigelM in forum Community Club House
    Last Post: 07-13-2010, 12:13 PM
  4. thread turning fanuc 10te
    By bruiserba in forum Fanuc
    Last Post: 03-27-2010, 07:01 AM
  5. Need help with live tooling on a FANUC 10Te/f
    By kangarabbit in forum Fanuc
    Last Post: 03-30-2006, 10:05 AM
