587,030 active members*
3,899 visitors online*
Results 1 to 14 of 14
    Aug 2005
    177
    Spiral Milling
    I have V28. I want to mill the perimeter of a part. I want to spiral down on outside instead of stepping down.
    How do I do this in V28
    Rob
    Dec 2013
    5714
    Re: Spiral Milling
    I don't use BobCad but I think I can give you a generic answer. I am assuming BobCad has spiral (angle?) lead in capability. Set your DOC to full depth, and set a shallow lead in angle. Then look at the tool path, adjust the angle as needed to get the approximate stepdown per pass that you want.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2012
    Re: Spiral Milling
    Quote Originally Posted by artracing View Post
    Rob
    HI there..I have BC/ V29 no outside spiral only Contour Ramping...
    Inside Pocket has spiraling.....
    Aug 2005
    177
    Re: Spiral Milling
    That might be a creative way to do it.
    I’ll try
    Thanks Jim
    Rob
    May 2013
    701
    Re: Spiral Milling
    Rob
    2 Axis -- Pattern -- Contour Ramping
    Aug 2005
    177
    Re: Spiral Milling
    Yes. You are right. I noticed the profile finish doesn’t have contour ramping. Wonder why.
    Apr 2009
    3376
    Re: Spiral Milling
    Probably because in a finish pass it is usually best to go full depth so you don't have tooling marks.
    Tool Pressure comes to mind (spring)
    Keeping the tool at one constant level,,,your cut might even be a few tenths of a thousand tapered,but it will be consistent.
    A few tenths at a contour tool path will show
    Aug 2005
    177
    Re: Spiral Milling
    Very true but there is a problem side milling 2.6 tall piece in one shot. Unless you have a 3” tall carbide mill that’s in the $300 range. Jim Sawson here showed you can use cheaper mill and spiral down. I did this finish cut with 4 flute and it was almost mirror finish
    May 2013
    701
    Re: Spiral Milling
    In the next window after contour ramping in parameter setting the -- depth per pass / depth of cut makes in easy
    Aug 2005
    177
    Quote Originally Posted by RAF. View Post
    Yes, very likely use it all the time now.
    Need to use it on 2” hole for better precise cut. Haven’t tried that yet.
    Apr 2009
    3376
    Re: Spiral Milling
    You can just use 2 roughing contour tool paths
    2nd one with zero left for finish
    Aug 2005
    177
    Re: Spiral Milling
    picked up V31
    Got mislead in contour milling. Plunge rate is new feed rate.
    no matter what you put in for feed rate it only follow the plung rate.
    Apr 2009
    3376
    Re: Spiral Milling
    Rob
    you could always use 3 axis wire frame
    albeit more time consuming,you would have to draw your tool path and draw leads and compensate for tool size
    May 2008
    244
    Re: Spiral Milling
    artracing
    this is contour ramping in 2 axis
    just enter the same feed rate for x y and z
    set feed plane just above the part something like .010-.020-.030 default is .100
    do not use a leadin
    use depth per pass and set it shallow to start (not knowing what cutter or material) cutter is critical musst plunge well
    finish pass would always be a sraight line cut
    if you want to use ramping for finish pass, just use side allowance for rgh and "0" for finish pass
    this is very useful toolpath
  1. Spiral Milling BobCAD V27
    By Peter Gillespie in forum BobCad-Cam
    Last Post: 06-01-2015, 07:38 PM
  2. Spiral Milling on 750
    By Nourisheng in forum Cincinnati CNC
    Last Post: 05-19-2015, 06:15 AM
  3. Spiral milling in a lathe
    By jsimon in forum G-Code Programing
    Last Post: 10-09-2014, 01:03 PM
  4. Spiral Milling
    By NickDP in forum G-Code Programing
    Last Post: 09-28-2011, 04:30 AM
  5. Spiral Milling
    By jlavery in forum Fanuc
    Last Post: 07-01-2010, 05:39 AM
