Hi all,
Since my 1100 is not accurate enough, I plan to use the 4th axis to do all the finishing passes. Basically, it will just be using Z, X, and A. How do you calculate feed rate when using the rotary table? Would feed rate programmed for X/Y be close enough? I'm using Sprutcam 11 and 8" tilted rotary table if you are wondering. Attached is the part I'm trying to make. Even the spokes will be done using the rotary table.
Thank you
