587,043 active members*
3,162 visitors online*
Results 1 to 20 of 30
    Dec 2017
    13
    Delta vfd settings
    Hello, I upgraded my cnc 1325 machine with new ATC spindle and vfd. I cant get it running. Can somebudy gave me the right settings for vfd.
    Vfd is Delta vfd b 11kw (vfd110b23a)
    and china HQD atc spindle 9kw air colling, GDL70-24z/9.0
    Thank you
    15362
    Re: Delta vfd settings
    Quote Originally Posted by Deluk View Post
    Thank you
    What Voltage is the spindle VFD Drive
    Mactec54
    Dec 2017
    13
    INPUT: 3PH 380-480v 50/60 Hz 25A
    OUTPUT: 3PH 0-480V 24A 18.3 KVA
    15HP
    FREQUENCY RANGE 0,1-400 Hz
    Thats writen on the plate
    ericks Guest
    15HP
    The values above do not match the model number you gave earlier??
    "VFD110B23A"
    Dec 2017
    13
    yes, i notice that, becoes the numbers iv been writen first time was taken from the first offer of dealer and than we change the inverter, so the correct numbers i have now are vfd110b43a, sory for mistake
    ericks Guest
    That's better
    - - - Updated - - -
    No need to apologize
    ericks Guest
    When you say you can't get it running.....have you connected the motor and programmed the drive?
    Dec 2017
    13
    I sucesfuly conected the motor and power up for first time, i put vfd to factory defoult settings of 60 Hz and and try to run it and didtnt happend nothing. now i changed the parameter 01-00 to 400 hz and motor is runnig, but there are other values that i need to program before i start using the spindle and not damage it, maximum fequency minimum voltage,... there are 15 pages of parameter to set and i am already lost, so i will be pleased if sombudy can tell me those comon setting to put it in vfd for this motor so i can start working on machine. thank you
    ericks Guest
    I know the Delta drives quite well...but i don't know the 1325 machine. I need more information to be able to help you. For your motor to run properly/safely you need to make sure all the relevant parameters are correct. You don't want to damage this expensive motor.
    ericks Guest
    Things i need to know....
    1) power supply voltage
    2) motor voltage
    3) motor freq
    4) motor full load current
    5) motor speed
    6) how you want to start the motor
    7) how you want to control the motor speed
    i will add more later, i might have forgotten important ones....please excuse this cause it's half past three in the morning here
    Dec 2017
    13
    Machine is actualy upgraded cnc china cheep router taht worked prfectly for 3 years, so i upgraded it with stuf i dont want to destroy , controled by weihong controler, it control vfd thru AVI and spindle speed with 0 -10 V. All details are on pictures.
    Dec 2017
    13
    Can you find all infos from pictures i uploaded or where should i look for them?
    ericks Guest
    can you please take a close up pic of the drive connections, i need to see what you connected to the control terminals of the drive
    ericks Guest
    I am off to bed now...if no one helps you, then i will give you the parameters later today
    15362
    There are not many parameter's that need to be set, as you have auto tuning, I have a set for these drives but have a question
    When you first ran the spindle did you run it through the VFD KeyPad or from your machine Control
    Mactec54
    Dec 2017
    13
    i tried both and work, here are the conection pictures.
    Attached Thumbnails Attached Thumbnails 20181119_092239.jpg   20181119_092228.jpg
    ericks Guest
    Thanks....i need to get hold of the manual quick.
    ericks Guest
    Are you saying you had it starting from both the machine and keypad?
    Dec 2017
    13
    No, i started from keypad, then i change the parameter 02-00 to from 0 to1 and 02-01 from 0 to 1 and machine buttons work, thats all i figured out for now, this motor parameter are confuzing me. I dont dare to run machine until they are inserted.
    ericks Guest
    Sorry for delay....i am at work and we had a few machines down. I usually set up the drive before i connect the motor
  1. Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    By johnansaro in forum Servo Motors / Drives
    Last Post: 03-02-2018, 06:16 PM
  2. Delta VFD EL 2.2KW settings
    By vakeiros in forum Spindles / VFD
    Last Post: 04-04-2017, 10:16 PM
  3. Wye-delta, delta-wye configurations?
    By mackeym in forum Phase Converters
    Last Post: 07-06-2016, 10:26 PM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. delta tau
    By Jeremiah in forum Servo Motors / Drives
    Last Post: 06-23-2006, 01:41 AM
