586,608 active members*
3,760 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Looking for alternatives strategy verses plunging my mill bit strait into the piece
Results 1 to 4 of 4
    May 2013
    170
    I am milling mainly Aluminum on my Haas mini mill, and currently for example I am milling a 2" x 2" square hole that is let's say 1/2" deep. My cam software creates code that just takes my end mill and brings it above that area and goes strait down on the area it's going to cut and then continues cutting the square area. ( in other words it goes strait down to the depth specified in my depth of cut in my G-code )
    I've been reading that this may be shortening my end mill life.
    I was going to consider having the mill make a 3/4" hole with a drill bit in that area to create a pilot hole for my 1/2" end mill to use as a starting point.
    Is there an alternative that I should be using?
    My cam software is somewhat limited on settings ( for example I don't have the option to come in at it at an angle )
    Thanks,
    Kent
    Dec 2013
    5717
    Re: Looking for alternatives strategy verses plunging my mill bit strait into the pie
    If you can't spiral in with the CAM software that you have, then you need different CAM software. What are you using now? I like CamBam for quick stuff, and use Fusion 360 for more demanding stuff, both have spiral in functionality.
    Jim Dawson
    Sandy, Oregon, USA
    May 2013
    170
    Hi Jim,
    I am using MeshCam for my Cam software.
    I have been considering making the move to Fusion 360 and maybe this will be the nudge that I needed.
    I will also check on the CamBam you mentioned.
    Thanks,
    Kent
    Nov 2006
    490
    I agree that it's a situation where a ramp or spiral entry would be certainly beneficial. With modern CAM it's so common that it's often the default method for pocket entry. And it's definitely true that the endmill itself probably doesn't want to plunge, though it may depend on the manufacturer. Many high-helix cutters want to be ramped down into their cut rather than plunge.
    I like to use a drilled plunge hole in situations where the pocket size is relatively small compared to the endmill used to cut it. Using a plunge hole will save the bottom cutting surfaces, but it probably won't speed things up with today's modern endmills made for aluminum. In the past, plunge hole was the go-to method because the drill had a higher material removal rate, but these days that's only true if you're slamming a carbide TSC drill through the material at 100 ipm. If not then using the same endmill will probably be the same, ultimately.
  1. Why does my end mill shimmy when plunging?
    By Involute in forum MetalWork Discussion
    Last Post: 11-03-2015, 10:21 PM
  2. Mill tool strategy question
    By mhackney in forum BobCad-Cam
    Last Post: 09-30-2014, 07:20 PM
  3. strategy for finding max MRR on mini mill
    By acannell in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2013, 12:20 AM
  4. Parting strategy for long 303 piece?
    By jbrookes in forum Haas Mills
    Last Post: 06-26-2012, 02:08 PM
  5. My laser do not cut strait
    By niklasn78 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2009, 05:38 PM
