586,655 active members*
3,045 visitors online*
Results 1 to 2 of 2
    Apr 2004
    38
    Mist coolant output not working
    Just installed a Fog Buster on my Dyna Mill with a Ajax(Centroid) control. I have hooked up a solenoid valve to the mist coolant output on the main board. When machine is up and running I try to actuate the mist coolant manually or through MDI(M07) and I get nothing the led on the panel does not light and I do not get a return on the screen that says mist coolant on. I have checked parameter 8 and it is set to (2) both coolant, is there something else I need to change or has anyone else had this issue. Flood coolant works fine in manual and MDI.
    Thanks !
    Feb 2008
    280
    Re: Mist coolant output not working
    It sounds like the mist coolant logic may be missing from your PLC program. Impossible to tell, though, without seeing the PLC program.
  1. No Fog Mist Coolant
    By Jim Dawson in forum Material Machining Solutions
    Last Post: 01-17-2017, 05:22 PM
  2. Alphacam mist coolant
    By Ron Thompson in forum Alphacam
    Last Post: 05-19-2015, 08:01 PM
  3. MIST COOLANT SELECTION?
    By Big Chips in forum BobCad-Cam
    Last Post: 06-09-2013, 02:48 AM
  4. How much air for mist coolant?
    By Memran in forum Benchtop Machines
    Last Post: 02-08-2012, 10:15 PM
  5. Coolant, Flood, Mist, WD-40, etc
    By Smitty911 in forum Benchtop Machines
    Last Post: 11-15-2009, 04:15 PM
