586,652 active members*
2,700 visitors online*
Thread: Form Tapping
Results 1 to 14 of 14
    Feb 2018
    17
    Form Tapping
    Hi all,
    I'm using an PCNC1100 with their ER20 floating tap head and YG brand M3 threadforming tap.
    I'm trying to form tap some M3x0.5 holes in AL6061 about 0.30" deep, hole depth is 0.40". The problem is, about the top half of the threads are being pulled out, so I can wiggle the screw into the hole past several threads before it stops and I have to start turning it.
    I have had success using thread cutting taps of this size and others with not issues.
    I checked on a manual mill, using the same 7/64" (0.109") drill and same M3 tap, power tapping with a Bridgeport quill. Threads are fine. Inspected the tap, threads are not damaged or galled up.
    So it must be something with my program or a setting.
    I've tried both my original program generated in Fusion360 and then I made a test program using Pathpilot covnersational, same results, most of the threads are pulled out of the hole.
    Is this a dwell time issue?
    Am I not setting the tool length correct? (I jog down to a piece of shim stock and zero minus the thickness of the shim when I feel friction, since the tap head is spring loaded, its not a hard stop like a drill bit would be).
    Any help would be appreciated.
    Re: Form Tapping
    I threadform a lot of small sizes (M3-M6), but by hand, and they do seem to take quite a bit more pressure than cutting taps. I'm wondering if the amount of torque with the tapping head isn't quite enough and so the Z movement is a little too fast for the rotation?
    Nov 2012
    591
    Re: Form Tapping
    What lube are you using? Tap Magic?
    Also, I believe there should be zero dwell if you can help it, but that would affect all the threads, not just the top.
    Feb 2018
    17
    Re: Form Tapping
    I watched the threads, I don't think its slipping, and I was able to tap using a drill chuck on a bridgeport. (These taps are brand new and have been in less than 10 holes of aluminum.)
    On the Tormach its held in a ER20 collet.
    I e-mailed Tormach, they responded within an hour. :cheers:
    They suggested either my clearance was too high (Retract is set at 0.20" above part, and clearance is 0.40" above part) or dwell was wrong.
    It could be the retract, if there is enough movement in the floating head, that it gets to the retract height and the rapid to the clearance height, it could be pulling the threads out with it.
    But then I checked my Dwell, its set at 0.2s ... So yea, that's probably it. Tormach suggested 0.5sec to give the head more time to catch up, which sounds right to me.
    So I'll try it again tonight. 3 tenths of second between scrap and $$. Fun stuff.
    Feb 2018
    17
    Re: Form Tapping
    Quote Originally Posted by jwatte View Post
    Yes, I'm using the blue Mist Coolant Tormach sells, which had been fine for cutting threads and general milling, but after the first ones pulled out, put some Relton A-9 Aluminum Cutting Fluid on the holes.
    Why dwell at 0?
    I feel like I've read that for pathpilot before, but that was before I had a Tormach.
    Mar 2009
    1863
    Re: Form Tapping
    If you’re using the E/C tapping head from Tormach, I have developed a process that works really well.
    I run my tap at 500 RPM and a feed rate of 10% less than your calculated feed rate going in and 10% faster coming out.
    When I thread holes 6-32 and smaller I use 5% compensation.
    And I use flood coolant.
    Jun 2014
    1780
    Re: Form Tapping
    sounds to me as if the spring pressure isnt enough to cause the tap to start biting into the hole but spinning until the pressure is great enough to start the tap.
    The dwell in Sprutcam is to let the spindle stop before reversing reversing the Z at the bottom or end of the tap CW cycle, before starting the CCW cycle, I use .5 seconds for 320 rpm, the higher the rpm the more dwell is needed.
    mike sr
    Jul 2007
    1602
    Re: Form Tapping
    Are you chamfering the hole before tapping?
    bob
    Aug 2018
    32
    Re: Form Tapping
    Quote Originally Posted by popspipes View Post
    X2
    Sent from my iPhone using Tapatalk Pro
    Feb 2018
    17
    Re: Form Tapping
    Quote Originally Posted by rowbare View Post
    bob
    Yes, a 0.120" chamfer for the 0.109 hole.
    I was able to get it to work last night. I set the dwell to 1.2seconds and I backed off the depth by 0.050".
    After this, all the threads felt good, tapped 140 holes this way with no problem.
    Still not sure what the problem is. But I noticed that the tap almost backs itself completely out of the hole before the head starts moving up to retract.
    Aug 2018
    32
    Re: Form Tapping
    Quote Originally Posted by hersh View Post
    I had that problem on a Hurco VMC with ridged tapping! Never found out the problem?
    7063
    Re: Form Tapping
    You can easily judge whether your g-code is correct by watching the tapping head as it taps a hole. In an ideal world, the head will compress SLIGHTLY, as the tap enters the hole, then remain a fixed length as it runs to full depth. It will then extend SLIGHTLY more when the spindle stops, then retract SLIGHTLY as the spindle reverses, and the head starts moving up. It should then remain fixed length until the tap is competely clear of the hole. If you see significant extension or compression of the tapping head, then your settings are off. If the tapping head ever reaches either limit of its travel, it's game-over, and a broken tap, or stripped threads, will result. On mine, I see very little extension or compression throughout the whole cycle - perhaps on the order of 1/8" absolute worst case.
    Ray L.
    Re: Form Tapping
    I set dwell at 1.0 sec at the bottom and up feed 10% slower when reversing back up. Both my 1100's work with this. Also make sure you are feeding to clear the part up far enough that the tap has exited before the rapid up move up.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Jun 2006
    3063
    Re: Form Tapping
    Quote Originally Posted by R.DesJardin View Post
    That's one of those lessons that one learns quickly.
  1. tapping : cut / form / mill + punch ?
    By deadlykitten in forum Okuma
    Last Post: 03-06-2019, 01:50 PM
  2. Form Tapping
    By dak1 in forum CNC Tooling
    Last Post: 05-01-2012, 06:20 PM
  3. Roll form tapping questions
    By stebanski in forum Haas Mills
    Last Post: 05-11-2011, 10:12 PM
  4. Large Form Tapping In 400 BHN
    By pwilson101 in forum CNC Tooling
    Last Post: 02-25-2011, 04:37 AM
  5. Form Tapping
    By behindpropeller in forum Haas Mills
    Last Post: 07-31-2009, 08:37 PM
