586,588 active members*
2,599 visitors online*
Results 1 to 8 of 8
    Jan 2015
    23
    metal 3D printer Z axis bed
    Hello, I've been working on a metal additive manufacturing machine for a while now and I'm still trying to figure out if there are any real drawbacks to using a chain drive to turn 4 screws. My weight capacity on the bed is around 350 lb which is why I was considering using a chain opposed to a belt. I'm not sure of the limitations of using chain and now this might affect accuracies.
    Any advice or information is greatly appreciated.
    Apr 2004
    5741
    Re: metal 3D printer Z axis bed
    Roller sprockets and chain drives have a lot more slop than timing belt type drive mechanisms. If your machine is basically a MIG welder with motion control, that might not matter, since the process is inherently imprecise. But if you're building a laser sintering machine, you'll want as much precision in your stages as you can get.
    Andrew Werby
    Website
    Jan 2015
    23
    Quote Originally Posted by awerby View Post
    Thank you for your response, that's more or less what I had expected. I suppose the best option is to go with a counterweight and use belts. I guess I could add weight to the counterweight as the print increases in Mass. Or at least gas struts to counteract the weight of the print bed itself.
    I'm using a micro plasma arc welder. I wouldn't really consider it comparable to Mig or lasers so it's hard to say.
    I had considered using worm gears at all four corners because they won't back Drive. Although I have already purchased a 400 watt Servo with brake.
    Apr 2004
    5741
    What's the difference between micro-plasma and MIG? It sounds like the same thing, just smaller. I'm not sure why you'd need a counterweight; it doesn't seem like the micro-plasma head will weigh much, and there are no cutting forces to contend with. I don't think it would make much sense to move the whole bed, when all you need to do is move the head. I also don't think a long rubber belt would work too well in the presence of the arc welder; the UV radiance and metal spatter wouldn't do it much good. Rack and pinion would probably be your best bet, and keeping that mechanism sheltered from the arc mess would extend its life.
    Andrew Werby
    Website
    Jan 2015
    23
    That's very true about the belts. Initially, yes I thought it didn't make much sense to move the bed. Although plasma arc welding is one of the fastest welding methods. My gantry is using direct drive 400w servos with 10mm ball screws. I don't think that at higher speeds I would have much rigidity even with a steel Construction and the bed is essentially a static load moving only fractions of a mm at any time.
    I'm not at all going for much penetration of weld. It's essentially hardfacing. So the rate at which that is possible to print as a bit unknown.
    Jan 2015
    23
    Regardless of if the bed or Gantry is moving vertically wouldn't a gear reduction on the screws at least reduce the backlash? I've heard of people having problems with repeatability. I'm not sure if a gear reducer would have any effect on the repeatability specifically.
    Apr 2004
    5741
    Adding more gears typically increases backlash, rather than reducing it. It does reduce speed and increases torque, but each gear has to have a little gap for clearance between each tooth, so it adds up.
    Andrew Werby
    Website
    Jan 2015
    23
    So if I move the Gantry instead of the bed I would think I would have less backlash throughout the print since the Gantry would just be moving up. Where if I were moving the bed down instead it would be creating backlash every time at moved. I could still see heat from the welder definitely being a problem with belts. The more I think about it the more I lean towards using spiral bevel gears with shaft connected in an H shape turning ballscrew at each end.
  1. Metal 3D Printer
    By Renz in forum Want To Buy...Need help!
    Last Post: 11-26-2016, 11:05 PM
  2. Converting a Laser Printer into Laser Metal Marker
    By hmsahir4u in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-10-2013, 06:09 PM
  3. 3D Metal Printer Startup Survey Request
    By toogle in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-01-2013, 09:54 PM
  4. MetalicaRap 3D metal powder printer Help!
    By Rapatan in forum 3D Printer / 3D Scanner Discussion
    Last Post: 08-23-2012, 11:44 PM
