586,471 active members*
3,988 visitors online*
    Dec 2006
    60
    Spindle Lock for SX3
    A while back someone mentioned that they would like a spindle lock on the SX3. I too thought that it would be a nice improvement. I was mainly interested in being able to lock the spindle for scratch engraving. I wasn't so much wanting a brake that could be used to slow the spindle to a stop. I think that could be better done with dynamic braking and would require a relay or two.
    Following are a couple of pictures of what I have done and one drawing.
    OM
    Attached Thumbnails Attached Thumbnails P5010078.jpg   P5010079.jpg   Brake Dwg.jpg
    Jan 2007
    122
    I had mentioned earlier the desire for a spindle brake but for tool changes, I am not to found of the spanner wrench on the bottom of the spindle. My goal is to be able to do a tool change with on tool or less. I am working on setting up a pneumatic draw bar system. It looks like you system of pinching off on the belt will work fine for your needs, please report in if you run into any wear or marking on the belt.
  1. m-code for spindle lock
    By fisholie in forum G-Code Programing
    Last Post: 10-06-2020, 04:03 AM
  2. Can I "lock" the spindle on a TL-1?
    By juxtoposed in forum Haas Lathes
    Last Post: 03-10-2009, 04:15 PM
  3. system lock up - USB
    By 1ctoolfool in forum Haas Mills
    Last Post: 07-23-2007, 04:17 PM
  4. User lock
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 11-22-2005, 05:38 PM
  5. spindle lock question
    By Scott-M in forum MetalWork Discussion
    Last Post: 12-01-2004, 02:18 AM
