586,983 active members*
3,557 visitors online*
Results 1 to 10 of 10
    Oct 2018
    13
    About To Buy A Tormach 1100M
    Hello,
    I am about to order a Tormach 1100M, I am familiar with Solidworks/Inventor but not with CAM software. I am getting this machine to make low volume gun parts/modifications to firearms as well as do some engraving on aluminum (logos/lettering). I just wanted to create an account her because I know I'm going to have questions along the way, and I also wanted to ask if anyone had any promo codes they weren't going to use.
    I plan to include my work in several videos on my YouTube channel, if anything is of interest to you guys I can hopefully share that stuff here.
    Thanks!
    Apr 2008
    19
    Re: About To Buy A Tormach 1100M
    As for CAM, I recommend you look at HSM for Inventor and HSM for Solidworks. For a small shop the license for Fusion 360 is free. Fusion 360 is similar to Inventor except everything is cloud based. HSM is included with Fusion 360. The biggest reason for going with these products is that the POST files for Tormach are actively updated. https://cam.autodesk.com/hsmposts? The conversational programming comes with your mill. Conversational works great for simple machining.
    Oct 2018
    13
    Quote Originally Posted by Sir John View Post
    Thanks for the reply! What does conversational programming mean?
    Mar 2013
    344
    Quote Originally Posted by The_Wound_Channel View Post
    The system will ask a few questions about what you are doing and what are the dimensions, depth of cut, feed rate, tool size etc. After you input your requirements it will generate ready to use gcode. For simple drilling, facing, profiling and such it's often quicker and easier to just write the gcode yourself. As for Fusion 360, it's a great program. Although, for me, I find it's not too intuitive. There are lots of tutorial videos on YouTube though many of them just demonstrate the presenter's "awesome" proficiency while not doing much tutoring. Lars Christensen has an outstanding Fusion 360 tutoring series. Watch a couple of his videos to get a feel for the program's many capabilities. As previously mentioned, Fusion's post default post processor for Tormach couldn't be easier to use and is always current. Fusion 360 will also output a file for a 3d printer slicer. I have a print job running at this moment that was created using Fusion 360.
    Oct 2018
    13
    Quote Originally Posted by jttoner View Post
    That's great info, thank you!
    Aug 2013
    980
    I would thing for gunsmith work, you will get into 4th axis work. Can you give the OP insights into how well fusion 360 does with 4th axis? Last I checked it was not very advanced yet but maybe that has changed.
    Mar 2013
    344
    All I di for 4th axis is manually code the moves and insert them into the F360 gcode. Not very elegant, but it works.
    Feb 2016
    34
    I find fusion more intuitive than solid works , it is simple to connect aspects of the sketches (fundamental drawings) to the cam potion of the program. I found forth axis indexing to also be very easy compared with solidworks ; however continuous 4th is still not possible or very limited in fusion
    One thing I’ve wondered about - a model railroader may be subliminally fantasizing about harmony between beautifully engineered machines and nature, or the human feat of creating shipping networks that extend further than we can see. Does a gunsmith fantasize about history, good wars , crisp civil order, and scenarios where it would become necessary to defend life? I really am curious what associations there are..
    I know hunting is also a factor- a fantasy about using simple / elegantly designed tools to shorten the distance between nature and ourselves. I understand this but not the other ideas in gun smithing .. any ideas?
    Jun 2011
    692
    Quote Originally Posted by jmosley View Post
    What have you found missing in Fusion 4th axis? I know the 4th and 5th axis support in Fusion CAM isn't as good as some, but it's certainly possible. I haven't used it myself yet so I don't know what snags there might be.
    Feb 2016
    34
    Quote Originally Posted by skrubol View Post
    I am milllng complex surface (polygonal or soline) forms that could take advantage of being turned in the 4th axis while roughing with an adaptive tool path or for finishing. The only continuous paths that I could access in fusion360 (where all 4 axises are moving ) is for tracing paths that are found in the construction of the model , such as engraving a path on a cylinder .
  1. Breaking in a new 1100M
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 08-24-2018, 07:27 PM
  2. 1100M Height
    By Blackmesa in forum Tormach Personal CNC Mill
    Last Post: 07-28-2018, 04:03 PM
  3. Tormach 1100M Info Possible Series 4!
    By Master_Arvist in forum Tormach Personal CNC Mill
    Last Post: 07-03-2018, 10:54 PM
  4. ANILAM 1100M
    By blakey235 in forum Controller & Computer Solutions
    Last Post: 08-03-2014, 12:01 PM
  5. anilam 1100m
    By pmesilver in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-01-2011, 06:05 PM
