586,489 active members*
2,290 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Multiple Fixture Offsets
    Aug 2005
    13
    I've got a question regarding the programming of multiple fixture offsets. I have one small part and instead of running it one part at a time I'd like to fixture 10 of them in chick type vises and run 10 per program. is there an easy way to do this. I'm using version 11 programming a FADAL.
    Thanks in advance!
    Mar 2006
    1013
    Are they equally spaced? Or are they random on the table? You want a different G5# fixture offset for each one?
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Aug 2005
    13
    Hi Mike,
    I'm looking to used different G5#'s for each part.
    Mar 2006
    1013
    Well it was nice that you answered one of the 3 questions I wrote.
    Mike Mattera
    Aug 2005
    13
    Mike,
    I guess I thought that with separate fixture offset numbers the other two questions were moot. I mean, don't you set up x0 y0 z0 for each G54, G55, G56.... and so on?
    In reality, the parts will be somewhat equally spaced just to keep everything close. and may end up being random on the table. This is a short run prototype so it's kind of a more flexible situation than full production parts.
    Thanks again, I'll try the Datum Shift! It looks like a somewhat time intensive way to program.
    Aug 2004
    23
    if the parts are spaced equally then you may want to check out the Matrix Mode, if you aint familiuar with the matrix mode then do a search in the help menu.
  1. Locating Fixture
    By 123sxu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-04-2009, 04:18 PM
  2. Multiple work offsets in mcx2?
    By Bullnerd in forum Mastercam
    Last Post: 03-25-2007, 05:14 PM
  3. multiple work offsets
    By rbest27 in forum Surfcam
    Last Post: 01-25-2007, 10:02 AM
  4. Q: Fixture plate for x3
    By Deviant in forum Benchtop Machines
    Last Post: 08-31-2006, 02:51 AM
  5. material for fixture
    By MBG in forum MetalWork Discussion
    Last Post: 03-12-2005, 08:37 PM
