586,983 active members*
3,750 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tool change table location V30
    Mar 2014
    55
    When performing tool changes and machining larger parts that may have a collision on tool change.
    Is there a way in either the post processor or in the software to tell the machine where to park the table at every tool change? Other than editing the post manually.
    Mar 2012
    1570
    Re: Tool change table location V30
    Yes you can create an advanced posting tab with a check box and input for the X Y Z location for the tool change. This would be done with a scripted post. It's not an in the box feature but it's something that can be added to your post with out that much work.....
    I've attached a sample scripted post for you to review. This post was created for V24 and will show you some the files and format needed to create a scripted post with and adv posting tab. I also recommend you search the help files on this topic because the help system will have more information for you.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  1. How to have Mach3 use an Auto tool zero location on the table for Zero of tools.
    By jimskeet in forum Mach Wizards, Macros, & Addons
    Last Post: 01-24-2018, 02:01 PM
  2. Manual tool change and tool table help needed please
    By LEARN in forum Mach Software (ArtSoft software)
    Last Post: 06-10-2014, 09:31 PM
  3. Setting Home Location, Table Travel, and Home Switch Location in Stepconf
    By northbear in forum LinuxCNC (formerly EMC2)
    Last Post: 08-25-2013, 05:07 AM
  4. Change tool locations to table?
    By Atlas18 in forum Techno CNC
    Last Post: 06-13-2010, 06:30 PM
  5. Tool change Location
    By flyboypete in forum Machines running Mach Software
    Last Post: 02-10-2008, 12:51 PM
