586,963 active members*
2,423 visitors online*
Results 1 to 17 of 17
    Jan 2007
    23
    1/4 NTP THRU 304 BAR
    The last time I had this job I went thru 3 taps (broken teeth) on ten parts.
    I tried drilling oversize, big chamfers, down to 15 SFM. Nothing seemed to work.
    I just got them again. HELP
    I don't want to do them by hand.
    HAAS VF3
    Mar 2008
    638
    Re: 1/4 NTP THRU 304 BAR
    Years ago I ran 1/4" NPT in 303 stainless. I used a tapered mill to get the correct taper before tapping. I also had a M00 to apply thick tapping fluid before each hole. I don't remember going through taps but it was years ago.
    Jun 2004
    6618
    What is the material? What kind of holes? What size and depth of holes? What brand and style of taps were you using? What speed were you tapping at?
    Lee
    Jan 2007
    23
    REGAL BELOIT, SOME "WHO KNOWS WHAT" 5/16 304 BAR
    Jan 2007
    23
    CUTTING LUBE
    RIGID EXTREME PERFORMANCE THREAD LUBE
    Jun 2004
    6618
    I assume you mean NPT. I think you need to have the perfect recipe of hole size, speed and depth to pull this off in a machine without breaking taps. I don't think I have ever seen a machine tap for an NPT thread. I am sure they make them, but I would not want to see the cost.
    I did see these at McMaster Carr, but they are still intended for hand tapping.
    https://www.mcmaster.com/2663a43
    Not cheap either.
    Lee
    Dec 2013
    5714
    304 is a PITA to work with. Maybe a thread forming tap would work? http://balax.com/sites/default/files...-Pipe-Taps.pdf
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2007
    23
    Quote Originally Posted by t_chance View Post
    NOW 3/8 THICK NOT 5/16
    Jan 2007
    23
    OTHER TAPS WHERE OSG ELECTRALUBE AND REIFF & NESTOR
    Oct 2011
    106
    Why not thread mill it?
    Mar 2010
    1852
    Pipe taps do not clear chips easily, so I would use 4 or 5 steps to do it. Decreasing amount of cut for each pass. Oversize holes for sure, as the standard for hand tapping has the tap cutting the sides walls way too much.
    Jun 2013
    1041
    I have tapped a ton of npt threads in ss. I have had trouble with thread tear out of threads but I don't think I've ever broke one. I use taps like these.
    https://www.regalcuttingtools.com/pr...aper-pipe-taps
    I set the rapid low. Just as the tap reaches the r plane and starts spinning I add a heavy dose of tap heavy from a oil gun. I follow the stream up the tap to the height of tapping depth. In the other hand I keep the air hose. As the tap is retracted I blow a constant stream of air directed at the entrance point of the hole. This usually results in a clean tap you can follow right to the next hole and repeat. If there are chip that don't come off I feed hold and remove before it starts spinning again at the next hole.
    Ben
    Sent from my E6810 using Tapatalk
    Jan 2007
    23
    Thanks Ben.
    That was the problem, packing chips. My taps never snapped off, just chipped out the teeth. I'll give those a try.
    Tom
    Mar 2017
    314
    Threadmill. costs the same as two pipe taps, lasts a long long time, makes beautiful threads that gage perfectly.
    Jun 2003
    1365
    Definitely thread mill.
    Apr 2005
    713
    4th vote for thread milling. Stop banging your head against the wall.
    Jan 2007
    23
    POINT TAKEN.
    I've banged my head against the wall for too many years. THANKS
    The boss wouldn't spring for anything more than a hand tap. He's a welder...
