586,463 active members*
3,516 visitors online*
Thread: confusion
    Dec 2004
    7
    Question confusion
    Dear all
    I am a little bit confused , these word are almost the same ? (routing - engraving - carving - lathing ) is it ??
    Thanks to all of you
    May 2005
    405
    Yes they are similar and English is a difficult language.
    Routing is normally refering to the use of a router and is cutting a trench or full thickness of the material.
    Engraving is normally on the surface and is often using a low powered spindle. Common engravings are pictures or letters.
    Carving is a 3 dimentional process. can refer to deep cut lettering.
    Lathing is a rotational process, and normally used to produce objects such as a pully or shaft.
    Jul 2006
    117
    these are all different words & special meaning as Paul had eloborated. however these all operations are carried on different machines & tools.
    Dec 2004
    7
    Red face
    So
    Which machine ( router or engraver ) do i need to make multi depth photo on MDF ( say ...mmmm .. like a face).
    Thanks to all friends .
    You need a router or engraver.
    A router will do larger heavier items like Pic.2 below, and can do some engraving with a small collet and the correct bits.
    An engraver will also engrave as in Pic.1 below.
    I don't know why anyone would want a machine built solely for engraving instead of a router that can do both, although I think there are 'engravers' used in the jewellery industry. Maybe they are just small routers more suited to fine intricate work.....
  1. Z position confusion
    By baldysm in forum MadCAM
    Last Post: 02-16-2007, 04:46 PM
  2. sofware confusion
    By craftech in forum Uncategorised CAM Discussion
    Last Post: 10-24-2006, 07:48 AM
  3. Manual.doc vs. .ini confusion
    By medved in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-04-2006, 04:18 PM
  4. Multiplier confusion
    By Mike F in forum Servo Motors / Drives
    Last Post: 01-03-2005, 08:36 PM
  5. VFD confusion, helllp!
    By Swede in forum CNC Machine Related Electronics
    Last Post: 06-15-2004, 12:05 AM
