586,525 active members*
3,451 visitors online*
Results 1 to 9 of 9
    Aug 2007
    224
    millplus connect to tncremo ?????????
    sir what is the value of machine constant of 311 and 313 ..this is use for data transmition thru Ethernet connection...with the help of tncremo...i want to connect my machine with pc..machine dmu80t with millplus grundig controller..right now my machine reply me when i use ping 192.168.0.57 -t but not connect with tncremo ..i believe that i have to change some machine constant ....but dont no how and what is the right value..
    regards
    asif
    hi I'm Nasser
    have you try using CDS-LIT software to connect you'r machine?
    Hi I have an old Millplus control and try to connect with TNCremo with no good result. I call to DMG Mori technical service and they said that software will not work with mill plus. They said need to get CDS Lite fron Heidenhain but is not available anymore. So as I know TNCremo will not work. we need to get a link to download the CDS Lite software... any clue?
    BR
    Finally got CDS Lite software (if anyone needs it)but still not communications between control and PC
    can i have CDS Lite becayse i need to connect my millplus dmu 50 evolution please??
    if anybudy can help please text me on my email [email protected]
    Mar 2019
    4
    Re: millplus connect to tncremo ?????????
    Quote Originally Posted by hectorm1randa View Post
    I had similar problem and I solved it with compatibility setting.
    just right click on shortcut icon of CDS-Lite and hit properties
    there under compatibility set "windows 95" and "run this program as an administrator"
    when you run the program first go to configuration and set your machine parameters (IP address....)
    hope this help
    Hello friends
    I have this problem
    I can't send files larger than 800 KB with CDS-lite
    Files larger than 800 KB are sent from the computer to the controller but But when executing files inside the control, we encounter an error message
    In addition, the file is sent by the network cable
    Please help me
    My gmail ( [email protected])
    Sep 2020
    Where can I download a CDS Lite software?
    Oct 2006
    71
    Hi, Can I please get a copy of CDSlite for my mill plus? Thx
