586,655 active members*
3,219 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > New (2 me) Fadal 4020 Trying to run first program and hits limit on Z axis
Results 1 to 10 of 10
    Nov 2010
    4
    I just got a 2001 Fadal that I'm trying to learn how to use and am having some problems trying to get my program to run
    I'm in Format 2 and have set my tool lengths to the table and work offset is Z+4.364 (set from table) in E1 (G54)
    It runs OK until it gets to the 1st tool change then it goes past the CS Z Position right to the limit.
    What am I doing Wrong?
    Program was created in MasterCam X3 with Fadal Format_2 4x Mill pst
    N1 O0007(T)
    N2 G20
    N3 G0G17G40G80G90
    ( 1/2 EM TOOL - 1 DIA. OFF. - 51 LEN. - 1 DIA - .5 )
    N4 T1M6
    N5 G0G90S2600M3E1X4.0672Y-1.85
    N6 H1Z2.
    N7 Z.1
    N9 X-.35
    N10 G0Z2.
    N11 M5
    N12 G90H0Z0. ------ Here Z goes up past Tool change height to hit software limit
    N13 M1
    ( TOOL - 2 DIA. OFF. - 52 LEN. - 2 DIA - .25 )
    N14 T2M6
    N15 G0G90S5000M3E1X.4651Y-.9229
    N16 H2Z2.
    N17 Z.1
    N18 G1Z-.028F12.
    N20 X3.2494Y-1.7111R.0193
    N21 X3.2301Y-1.7303R.0193
    N22 G0Z2.
    N23 M5
    N24 G90H0Z0.
    N25 E0X0Y0
    N26 M30
    Jul 2006
    367
    Re: New (2 me) Fadal 4020 Trying to run first program and hits limit on Z axis
    I would change your G90H0Z0 to something like this G28 G91 Z0.
    pete
    Apr 2014
    345
    Do you have a negative length tool offset?
    Nov 2010
    4
    Yes tool offset is negitive.
    Apr 2014
    345
    Did you try adding a g28 g91 z0?
    This is a bit of one of my programs
    N10 G90 G94 G17
    N15 G20
    N20 G28 G91 Z0.
    (FACE3)
    N25 M9
    N30 T3 M6
    N35 S4000 M3
    N40 G4 P45
    N45 M8
    N50 G90 G0 E5 X4.92 Y-1.
    May 2005
    53
    You just need to combine your xyz into one line.
    G0G90X1.Y0E1Z3.H1
    The z value in your fixture offset exceeds the plus value above the z cold start limit. Even though you didn’t command the z axis in your first xy line the controller thinks it has to move the z by the fixture offset amount to maintain z zero. I use both tool lengths and a z value in my fixture offset all the time. Hope this helps!
    Apr 2014
    345
    Quote Originally Posted by Techman View Post
    G0G90X1.Y0E1Z3.H1
    That should work too. The g91 will also solve it and he could just throw that in to the code vs trying to change a bunch of stuff.
    May 2005
    53
    Whoops! Just re-read the original post. He will have a crash on line 5 and line 12. Line 5will hit the limit because of his z offset value. Line 12 will hit it again because the fixture offset is still active. I changed my master cam post to put out combined xyz moves on the first rapid line and an M1 immediately after every tool change. No wrecks and works every time.
    Mar 2008
    683
    The Tx M6 command will bring the z up regardless of offsets. Why put in the extra codes with "G90H0Z0."
    Nov 2010
    4
    I tried g28 g91 z0 and it worked
    will try just a Tx M6
    Just annoying that i have to edit posts.
    Is there a way to modify the post in Mastercam so I don't have to edit each .nc file?
  1. Replies: 4
    Last Post: 02-07-2018, 05:25 PM
  2. 93 4020 fadal 4th and 5th axis
    By bthomps5 in forum Fadal
    Last Post: 06-19-2012, 01:48 AM
  3. FADAL 4020 Z-AXIS WON'T GO!
    By TRACYPFAB in forum Fadal
    Last Post: 05-27-2010, 02:44 PM
  4. Fadal 4020 stops at line 13 or 16 in program
    By ThatguyDave in forum Fadal
    Last Post: 09-09-2009, 08:57 PM
  5. factory warm-up program for fadal 4020
    By wdwrd68 in forum Fadal
    Last Post: 08-15-2009, 01:02 AM
