Hi.
I have one of these: https://www.ebay.com.au/itm/Router-B...-/263135935588
With a 2.2kw spindle I have been running it at 12000rpm 4000mm/min feed IIRC taking a 1mm cut. I think I will up the feed rate a bit since the chips I'm getting aren't very big & there's some 'powdery' waste.
THe question that's puzziling me - there's a 9.5mm (3/8") vertical cut length - but what is a 'reasonable' cut to take with this behemoth? I ramp it over 25mm.
I'm relatively inexperienced.
Rob.
