587,002 active members*
2,938 visitors online*
Results 1 to 9 of 9
    Wire order for Powermax 2?
    Hello,
    I do the airplane design and my father helps out with the CNC.
    We're stuck on getting the wire order right for the board.
    Let me know any information you may need to help.
    The photo: DSCF5805.JPG (bottom right)
    Is the wire colors which show no resistance when connected to each other.
    Thanks!
    Steve
    Attached Thumbnails Attached Thumbnails DSCF5785.JPG   DSCF5786.JPG   DSCF5788.JPG   DSCF5790.JPG
    Oct 2004
    742
    Using your photo (link below) use the wiring for the left hand stepper for 6 lead unii-polar connection.
    Wiring:
    A = A on driver
    B = a on driver
    +Voltage = Common on driver
    C = B on driver
    D = b on driver
    http://www.cnczone.com/forums/attach...9&d=1177207230
    Hope this helps.
    Jan 2007
    22
    Steve:
    Where did you get the wire connector (pic 2 and 3)for the Powermax II
    Yes close thanks. It is the motor wire order.
    Here is more specific:
    We are not sure how to wire Powermax II Model P21NSXC-LSS-NS-03 Step motors for the 4-lead bipolar parallel connection shown in your installation bulletin.
    Our Question:
    Are the windings brought out physically in number sequence 1 to 8 or 8 to 1 or actually as shown on your diagram, which would be
    perhaps 6-2-5-1-8-4-7-3
    Mar 2006
    759
    6&5 are A, 2&1 are B, 8&7 are C, and 4 &3 are D
    or
    6&5 are A
    2&1 are A-
    8&7 are B
    4&3 are B-
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Quote Originally Posted by sloper sty View Post
    You can't wire it bipolar with a HobbyCNC board. Unipolar only.
    Mar 2006
    759
    Oops. I thought they were wiring it for another board. Good catch, Ger.
    -RedGreen show.
    Oct 2014
    Re: Wire order for Powermax 2?
    Hi
    Can anyone help, I am trying to find the correct wiring when connecting this stepper motor Powermax II Model P21NSXC-LSS-NS-03 with 8 pins numbered 1-8 to the Modellbau Letmathe foam cutter board with 4 connections per motor labelled A,A+,B,B+
    Jan 2007
    146
    if you look at the 4th picture from the bottom (dscf5803.jpg) it show how to wire parallel.
    A = black & white/org
    -A = orange & white/black
    B = red & white/yellow
    -B = yellow & white/red
  1. Hitachi 254Y wire machine or anybody with wire knowledge!
    By Shreimer in forum EDM Discussion General Topics
    Last Post: 02-23-2013, 10:49 AM
  2. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-26-2011, 10:47 AM
  3. Mitsubishi wire type setting for zinc coated wire
    Last Post: 01-25-2011, 01:49 PM
  4. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 05:18 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
