586,655 active members*
4,051 visitors online*
Results 1 to 9 of 9
    Mar 2007
    34
    engraving a piece with varying thickness?
    I have been looking for lasers, i have found a few however i now have a problem. I am looking to engrave something with varying thickness. Will autofocus be able to compensate? The second problem is. The thing I want to engrave are about 1 to 2 inches thick. I dont believe most lasers will go up high enough...what do i do? =(
    Finally. How much power do i need to engrave anodized aluminum?? How about to cut 1/2 acrylic?
    Aug 2006
    65
    9lrac9... You were doing fine on the first request of the laser, but the engrave of al, and cut 1/2 ac, now you talking some big money, not going to be just a hobby machine. Contract the work out and save for big machine.
    Mar 2007
    34
    well its not exactly engraving...more like laser marking, burning away a little bit of the anodizing, nothing deep or even a noticeable reduction in material.
    Aug 2006
    65
    Now you say...You can buy the toy machine. it will work ok. Except the cutting of the 1/2 plastic. You will need the larger machine.
    9lrac9 ie more power scotty...
    Mar 2007
    34
    cool stuff...the cutting of the plastic i can contract out as its just a set design. Thanks =D
    Jun 2006
    47
    Cutting 1/2" acrylic
    Hi, Just stumbled across the thread.
    1/2" (12.7mm) can be cut with a 50w sealed glass co2 laser.
    We do it on a Redsail RS5070 (M700) machine. This has a work area of 700x500mm (27.5"x19.7") also, the 'C' version of the machine has an adjustable table which allows up th 260mm (over 10") material depth! This is actually designed for a rotary attachment and works well on static items as well.
    Have a look at out web site for spec's. http://www.ctrlasers.co.uk
    Best regards. Neil (for CTRfuture Ltd).
    Mar 2007
    34
    does your machine have an autofocus feature? This is very important as some of the things i need laser engraved vary in thickness and a non-autofocus machine would be baaaad
    Jun 2006
    47
    Auto focus?
    The Redsail machines do not have auto focus. However, i think there is confusion of the phrase.
    To the best of our knowledge, there is no machine on the market that has what you are looking for. A better name for it would be 'follow-focus'.
    Auto focus, as it stands, only replaces the initial focus procedure at the start of a job. This takes just a few seconds to do manually; not a great saving considering the additional cost!
    To have a continuous focusing system would need an incredibly fast servo system when you consider that the head is scanning at meters per second.
    For example: Running at 6m per sec. and tracking a 10mm rise and fall variation in 100mm of travel. This would require a servo system to 1/ read the variation. 2/ calculate the rate of change. 3/ Drive the servo, all in 0.8ms per 1mm of change. Also the acceleration would need to be incredible.
    I'm sure someone out there can calculate the G forces!
    Back to the Redsail machines: We did some tests on variations in focus depth.
    We found that a variation of 4mm caused virtually no deterioration in image quality of a jpg file on slate. This may depend on the particular image; we did this trial for a customer some months age with their file.
    I hope this information helps. Neil (for CTRfuture Ltd)
    Mar 2007
    34
    318.87 g's to be exact.
    Thanks for the info though that was extremely helpful (especially about the test run)
  1. Minimum sheet thickness?
    By GalaticDan in forum Waterjet General Topics
    Last Post: 11-30-2006, 05:01 PM
  2. What is the greatest thickness
    By mbkowns in forum Vacuum forming, Thermoforming etc
    Last Post: 10-30-2006, 04:33 PM
  3. Creating specific thickness PET
    By screenzzzz in forum Vacuum forming, Thermoforming etc
    Last Post: 07-23-2006, 03:40 AM
  4. Mirror thickness
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-04-2005, 08:32 PM
