586,713 active members*
3,167 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Z Axis ball screw run out Help?
Results 1 to 8 of 8
    Apr 2017
    8
    Hello,
    Im new to the CNC world and Im needing help with runout on my Z-Axis. I have taken it apart 3 times and replaced the stepper motor mount-ball screw bearings. Today I think I have found the problem just don know how to fix it.
    As I was trying to tram the head to the Colum with a 1/2 drill rod in the spindle I noticed as I raised the head the test indicator was moving back and forth about .050 . I also could see the ball screw through the opening in the column moving back and forth also. Is this normal or did I miss something in the insulation.
    Thanks Anthony L
    Apr 2004
    5742
    Re: G0704 Z Axis ball screw run out Help?
    Are you sure the machining on the end of the ball screw, where it goes into the bearing, is concentric with the rest of the screw?
    Andrew Werby
    Website
    Apr 2017
    8
    Andrew I don't know. What the easiest way to check?
    I have the ball screw out of the machine and rolled it on a surface plate. It has like a slight bend in it. I can slide a peace of paper under the screw about 8 inches from the motor connector end. Maybe .005 Dif from the plate to the screw.
    Anthony L
    Apr 2004
    5742
    A bent screw can also cause problems like the one you noticed. To check for a discrepancy between the machined end and the rest of the screw, roll it on your surface plate with a dial indicator on the end.
    Andrew Werby
    Website
    Aug 2008
    962
    Sounds like you might need to adjust the gib on the Z dovetails.
    Movement of the head is a sign that the dovetails are too loose.
    A screw that has an .005 bend should not cause any wobble in the head with the dovetails properly adjusted.
    A screw with end machining that's out of concentric by .005 would likely bind up near the end that's out (if the dovetails are properly adjusted)
    Apr 2017
    8
    Ok,
    I put the Z back together and run it up and down fast and I can see the saddle twisting left to right. MARSH I have not tried to tighten the gibs up. That would be great if its that all needs to be adjusted.
    I don't have any V blocks but I have some 123 block. I rolled the screw on the blocks and the screws worse spot is in the middle .008 and on the bearing end where the screw has no threads I'm getting .016
    Apr 2017
    8
    Guys,
    I feel like I'm missing something here. I wish I would have taken a video. This thing look bad when running up and down. Can the double ball nut mount and the stepper motor/bearing mount be out of aline?
    Anthony L
    Apr 2017
    8
    ok,
    I put the Z axis back together and tighten up on the gib. It got indicator sweeping down to .003 well now I have .020 sweep on the Y axis. It can be more or less. Depending which way the ball screw is turn.
  1. G0704 ball screw question
    By i8avet in forum Benchtop Machines
    Last Post: 08-25-2017, 02:23 PM
  2. G0704 Ball screw choices
    By ny_racer_xxx in forum Benchtop Machines
    Last Post: 02-08-2017, 01:19 AM
  3. G0704 CNC Conversion - Ball Screw "wobble"
    By janz99 in forum Benchtop Machines
    Last Post: 01-07-2017, 10:46 PM
  4. Grizzly G0704 CNC Ball Screw Kits on ebay or direct
    By arizonavideo in forum For Sale Only
    Last Post: 02-01-2015, 05:05 PM
  5. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
