586,761 active members*
8,013 visitors online*
    Jul 2007
    139
    AXYZ Post Processor Issues
    Anyone else here using an AXYZ CNC router? I've been having some strange issues when it comes to 3D surfacing tool paths. Everything looks good in Fusion, and they also check out fine in an online G code viewer, but when I run a program on the machine, it skips random lines of code, completely screwing up the parts I'm trying to machine. 2D operations work fine, as do 3D roughing paths, but finishing strategies like parallel, scallop and radial aren't reliable, despite checking the code to ensure it posted correctly. My current theory is that it drops lines only when there are a lot of continuous 3 axis moves, and that it's related to the AMC2 motion controller "optimizing" motion trajectories.
    AXYZ wants to charge a lot of money for a service call, and I suspect they'll just tell me to use an officially supported post processor. Has anyone else come across these issues?
    Apr 2015
    327
    Re: AXYZ Post Processor Issues
    it is not look on a post issue. Looks some problem with a drive control.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Jun 2015
    68
    The only way I was able to get Fusion to work on an A2MC is to use the generic fanuc post processor.
    Cheers Ryan
    MrSolution Guest
    I know what's your problem. I will write you it in PM. If you need post, pm me too.
    Cheers
  1. AXYZ ToolPath Issues
    By cselby in forum Commercial CNC Wood Routers
    Last Post: 09-18-2017, 11:56 AM
  2. need help- post processor for mastercam needed for my axyz series 6010
    By ddemirovic in forum Post Processors for MC
    Last Post: 06-19-2017, 06:42 PM
  3. UCCNC Post Processor Issues
    By Andrew22 in forum Autodesk CAM
    Last Post: 05-10-2017, 02:55 AM
  4. Post Processor Issues
    By jrmach in forum BobCad-Cam
    Last Post: 10-18-2012, 08:48 PM
  5. mastercam 13 post processor issues
    By millertyme in forum Post Processors for MC
    Last Post: 01-05-2009, 10:42 PM
