586,655 active members*
3,482 visitors online*
IndustryArena Forum > CAM Software > CamWorks > How to get rid of line numbers in NC code
    Apr 2007
    Does anyone know how to set up the post process options to get rid of the line numbers?
    Aug 2005
    249
    It depends on how you edit your post processor. If you use the UPG then under the MISC tab in the Sequence and Sequence Output section select No Seq. Numbers.
    If you manually updat the posts in Notepad or the like (which is what I do) the modify the :C: SEQ_CONFIG=(YOUR VALUE) TO :C: SEQ_CONFIG=3 IN THE :SECTION=CALC_INIT_CODES. See below:
    :C: DEFINING_MACRO=NO
    :C: OFFSET_RESIDENT=NO
    :C: SEQ=1
    :C: SEQ_INCREMENT=1
    :C: MAX_SEQUENCE=99999
    :C: WORK_COORD_CONFIG=NO
    :C: END_OF_TAPE_PRELOAD=NO
    :C: NO_SMALL_ARC=NO
    :C: ARC_ROUNDING_POINT=.00005
    :C: HOLD_Z_DOWN_FLAG=0
    :C: LAST_PRELOAD=0
    :C: SEQ_CONFIG=1
    :C: AIC=1
    :C: COMP_OFFSET=0
    :C: FEEDTYPE=1
    :C: N=N
    :C: MULTIAXIS_TYPE=0
    :C: ROTATION_DIRECTION=0
    Hope this helps.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
  1. Centroid M400 code numbers
    By h_2_o in forum Centroid CNC Control Products
    Last Post: 11-06-2019, 02:33 PM
  2. Line numbers Fanuc OMD
    By Gncc50 in forum Fanuc
    Last Post: 08-22-2007, 07:30 PM
  3. Seeing what line of code the machine is at?
    By greasetattoo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2007, 08:47 PM
  4. G-Code Line Numbers?
    By Imagineering in forum G-Code Programing
    Last Post: 08-17-2005, 01:26 PM
  5. Perhaps a bug in simple one line code??
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-03-2004, 03:21 AM
