586,655 active members*
2,930 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > RDworksV8 plugin not working for corelDRAW graphics suite 2018
Results 1 to 15 of 15
    May 2018
    https://youtu.be/9CMH1yQkrX0
    This video describes what should be happening...i doesnt work. i get no icons, only error messages(corel draw not installed) does anyone know if its due to the newer software version...or my stupidity??...sorry...graphics suite 2017
    Feb 2007
    4553
    Re: RDworksV8 plugin not working for corelDRAW graphics suite 2018
    Greylee,
    See attached YouTube video:
    https://www.youtube.com/watch?v=SdO-nfTim8A
    Latest version of RDWorks:
    http://www.rd-acs.com/down_complex.aspx?FId=n14:14:14
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Post Re: RDworksV8 plugin not working for corelDRAW graphics suite 2018
    Greylee,
    It does work however the installation process is not documented very well.
    Jeff...
    May 2018
    Angry Re: RDworksV8 plugin not working for corelDRAW graphics suite 2018
    Quote Originally Posted by jalessi View Post
    Greylee,
    Jeff...
    the video shows(again CDxversion.)...however the screen shot offers some hope.....but even tec support for corel & rd works says it wont work
    Dec 2014
    187
    Did anyone else install RDWorks onto CorelDraw 2018?
    I tried following the below, downloaded the Version shown below and Followed the YouTube Video but can't get past the first Install Screen.
    When I select CorelDraw Laser, then check "Plug LaserWork" it says "Can't find the installation of CorelDraw" if I check "Locate install path" and select "c:/Program Files/Corel/CorelDRAW Graphics Suite 2018" Folder, it asks for the CorelDraw version and the latest shown there is "CorelDraw 12". Selecting that it gives and Error "Install Failure"
    I have looked on Youtube but can't find any help there.
    Feb 2007
    4553
    Quote Originally Posted by KenR60 View Post
    Ken,
    Certain versions of RDworks have compatibility issues.
    1: View the attached video https://screencast-o-matic.com/watch/cF1i0NFcZv
    2: Download and install this version of RDworks http://www.rabbitlaserusa.com/Driver...tup8.01.26.exe during the CorelDraw portion of the installation you must select version 8 not version 12
    See attached image
    Hope this helps,
    Jeff...
    Dec 2014
    187
    Hello Jeff, Thanks for the Help, much appreciated! I have 2 versions installed, X8 and 2018, I have tried to "Locate Install Path" for both X8 and 2018 but still getting an error.
    Selecting the Folder "CorelDRAW Graphics Suite X8" and X8 shows the error "Install Failure"
    Selecting the Folder "CorelDRAW Graphics Suite 2018" and X8 also shows the error "Install Failure"
    So is there a folder within the above directories that I need to select?
    Feb 2007
    4553
    Did you try the 8.01.26.exe version of RDworks?
    Dec 2014
    187
    Thanks Jalessi, I had tried the Latest version of RDWork so I tried the 8:01.26.exe and all worked up until trying to run the Macro in CorelDraw. I have attached the Dialog before and after pressing Run
    Feb 2007
    4553
    Ken,
    Unfortunately I have seen users that have installed another version of RDworks first and had the error you are experiencing.
    The solution I have found is to completely remove all versions of RDworks, make sure you remove "C:\RDWorksV8" then completely remove CorelDraw and start over first install CorelDraw 2018 then install the RDworks version I have suggested.
    Let us know how you progress.
    Good luck,
    Jeff...
    Dec 2014
    187
    Thanks Jeff, Un-installed everything and Re-installed everything.
    No Errors this time, until I tried to send a test to RDWorks and got the error below.
    I re-installed RDWorks, tried again but the same error. Tried RDWorks directly just to see if it worked and the exported Test loaded with RDWorks.
    So Yes its Working but No it isn't :-) I searched for the dll but came up with nothing.
    Ken,
    Good luck,
    Jeff...
    Feb 2007
    4553
    Ken,
    In programs and features is only one version of RDworks installed?
    Dec 2014
    187
    yes Jeff, just the one installed
    Ken,
    Feb 2007
    4553
    Ken,
    How are you sending a test to RDWorks without CorelDraw installed?
    Please explain in detail, step by step, what you are doing, so that I can replicate the issue.
    Jeff...
    Dec 2014
    187
    Oh I thought I'd replied to this but seems I must have forgotten to press Send.
    Here are the Steps I took
    1) Un-installed CorelDRAW 2018
    2) Uninstalled RDWorks
    3) Installed CorelDRAW 2018
    4) Installed RDWorks
    all worked as planned to here.
    5) Added RDWorks to CorelDRAW
    6) Drew a Rectangle and Circle, Clicked on the RDWorks Toolbar Icon and got an Error and RDWorks didn't load
    7) Went to the Start Menu and Ran RDWorks and it loaded with the correct results.
  1. Working on a custom software program to generate tool paths from graphics.
    By WayneHill in forum Uncategorised CAM Discussion
    Last Post: 07-30-2019, 12:38 AM
  2. rdworksv8/temp/0.tmp contains a invalid path.
    By GeneMpls in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-23-2017, 09:54 PM
  3. Corel Draw Graphics Suite Or Technical Suite?
    By Klausm2 in forum Redsail Laser
    Last Post: 06-23-2016, 10:45 AM
  4. KM5P graphics screen not working.
    By bgmnn in forum HURCO
    Last Post: 02-07-2015, 04:49 AM
  5. Corel Graphics Suite 11 from 2003
    By der_fisherman in forum Uncategorised CAD Discussion
    Last Post: 12-17-2009, 07:04 PM
