How's the X3 grizzly - is it ready to go or is it a kit of parts like some HF machines? I haven't touched or more importantly used an X3 so input from those who have would be hugely welcome.
How are the gibbs and ways? are they smooth out of the box or is there a lot of adjusting or lapping required?
How's the alignment in x,y and z? Tables flat? Anyone had to skim the table flat? Anyone using a magnetic table with an X3?
Thinking of buying one and cnc'ing for a specific need. It will be a low volume (50 a week) production of parts in cold rolled mild steel, 6061 and maybe stainless ( or not if I can avoid it). All parts are under 1"x3.5"x1.5", problem is I'd need to hold tolerance to +/-0.01 (ten thou) in dimension AND more importantly square. All parts would use the same e/mill so no tool changing for each part required.
What's the concensus; is an X3 up to that?
Andrew
