586,584 active members*
2,726 visitors online*
    Sep 2005
    66
    STL to CAD files
    Hey there all,
    I need to find a program if one exists that will allow me to transfer .STL files to a format that will allow a CAD software program to read them. I need it to be IGES, STEP, , etc so I can machine the part that has been converted.
    Anyone know of such a program?
    Any help would be appreciated
    Apr 2018
    36
    Re: STL to CAD files
    Turbocad or
    Mastercam.
    Usually your CAM program can import an STL. pretty common format.
    If you are looking to convert the .stl into a solid or surface model, you really can't.Even if you could, it wouldn't be any better than the .stl. That's like turning a pencil drawing into a photo.
    Jan 2004
    3154
    like Gerry said an STL file is not really a solid. it is made from triangles, it is machinable but won't be smooth
    www.integratedmechanical.ca
    Apr 2004
    5741
    You can machine directly from a STL mesh file, if you use a CAM program that can deal with them - DeskProto is one. If it is tessellated too coarsely, you'll see faceting in your machined parts, but if the triangles are small enough you won't. There are "surfacing" programs that let you construct different kinds of geometry over the top of your mesh files, if you really need NURBS or parametric formats, but you'll usually lose some detail when you do that. On the other hand, the new surfaces will be smoother. But if all you want to do is machine the parts, you don't really need to do that.
    Andrew Werby
    Website
    Sep 2006
    245
    As mentioned previously, TurboCAD (and possibly many other CAD programs) can import STL files. The scale may be off it it was drawn in mm and loaded in with inches. That is easy to fix. If the object is not smooth enough, then you may have to re-draw all of the surfaces to create a new 3D object that matches the outline of the STL object.
    Steve
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. RFQ: Convert SolidWorks files to MDD files for Hanwha XE20
    By THPP in forum RFQ (Request for Quote)
    Last Post: 02-23-2017, 02:08 AM
  3. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  4. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  5. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum WoodWorking Topics
    Last Post: 05-09-2013, 02:15 AM
