586,536 active members*
3,100 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Jun 2021
    Re: Probe Wizard for Mach3
    Quote Originally Posted by n0f8r View Post
    Thanks Eric, yes - I did see the warning on your site about Chinese controllers - but China is a big place! although when I bent the probe tip I realized your rule of thumb definitely applied to my controller. Eventually I re-read your page and saw the notes on controllers that work (I'm an inveterate skim reader) - I ordered a CNCDrive AXBB-E yesterday. It's Ethernet not USB, but that's probably better, and very affordable when ordered direct.
    cheers,
    Kevin.
    Hi Kevin,
    I have the same card. Were you able to resolve the probing issues? If not then what replacement card did you use.
  2. #22
    Jun 2021
    Quote Originally Posted by SoThatsIt View Post
    Hi Majorstain.
    I had a similar problem using the z probing in the wizard. It turns out that in the SafeMoveZ function (https://github.com/verser-git/ProbeW...acros/M917.m1s line 188) there is a threshold of 0.01.
    If Abs(ZHit - Zstart - Z1) > 0.01 Then
    I don't know exactly why, maybe it's due to the accuracy of the machine, but 0.01 was too small for me. I use 0.02 and then it's fine.
    This function is similar in all files so if you face the problem you may have to change it everywhere.
    Best.
    Hi There,
    i even tried to increase the value to 5.01 for both z hit and xyhit. But I am still getting following error.
    Sun - 19:18:04 ---X+ = 204.109375
    Sun - 19:18:07 ---Error! Probe tripped during XY movement
    Sun - 19:18:07 ---Return to the search position is interrupted
    Do you have any idea why that might be.
  3. #23
    Dec 2019
    5
    Quote Originally Posted by cnckd View Post
    Hi There,
    did you ever figure out the problem?
  4. #24
    Sep 2023
    Does anyone have the user manual for the Wizard? The Link doesn't seem to work anymore.
  5. #25
    Apr 2023
Page 2 of 2 12
  1. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  2. G32 macro or wizard for Mach3
    By Coolant Slinger in forum Mach Wizards, Macros, & Addons
    Last Post: 03-08-2013, 12:02 AM
  3. Mach3, Probe, and Digitize Wizard Issue
    By vicrider in forum Mach Wizards, Macros, & Addons
    Last Post: 06-02-2011, 07:58 AM
  4. mach3 threadind wizard
    By valmet58 in forum Mach Lathe
    Last Post: 11-21-2010, 08:00 PM
  5. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
