586,576 active members*
3,483 visitors online*
IndustryArena Forum > CAM Software > Vectric > Having much difficulty in making a 1.5” medallion
    Sep 2003
    1472
    Using Vcarve Pro 8.5
    I trying to make a 1.5” round medallion (acrylic) with arched text at the top and bottom, and horizontal text in the center, all text is 0.2” high, and cut with a 20 digree V bit.
    The preview only yields a few dots. Am I trying to do something that can’t be done?
    I would surely like some help.
    Re: Having much difficulty in making a 1.5” medallion
    Without seeing the file, or having more information, it's hard to say?
    Are you using a V Carve toolpath? Do you have a Start Distance entered?
    Feb 2020
    Try a deeper cut depth (fixed - 1/3 the material thickness) - the 20* bot might be causing the software to default to a too shallow depth. Typically, the lower the degree the deeper it needs to cut to get legible text.
    The attached files were cut with a 20* vbit. 0.375" Poly carbonate - 3.5" o.d. with a 1.0" center.
    Clint
    Attached Thumbnails Attached Thumbnails JP tsuba closeup.jpg   JP tsuba unlit.jpg   JP tsyba.jpg
  1. Having difficulty sourcing spindle for my needs
    By outsider787 in forum Spindles / VFD
    Last Post: 05-08-2016, 11:32 PM
  2. HPC laser software difficulty?
    By Dean357 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-22-2014, 03:43 PM
  3. Difficulty with layer management
    By Dstamp in forum BobCad-Cam
    Last Post: 01-07-2014, 06:45 PM
  4. Not some tiles to be waterjet cut for a medallion pattern
    By bonmotwang in forum Waterjet General Topics
    Last Post: 04-15-2012, 04:50 AM
  5. Difficulty of installing DRO on lathe
    By Cory in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2007, 03:22 AM
