586,920 active members*
2,537 visitors online*
Results 1 to 7 of 7
Hybrid View
    Oct 2009
    4
    Angry Multi Cam MG103
    We have a MG103 and are having some weird problems. It seems to be losing home when it goes to cut more than one pass, we were cnc some 1" HDPE and each pass would be off .062 so you would get a part with a bunch of steps on it. We have tried resetting home and that does not work. I talked to multicam, but not much help. The problem started on just the X axis but now has moved to both the x and y. This problem started a while back and seemed to be heat related. We have been running the machine with the controller door open and a fan on it. That helped for a while but now it does not. We examined the control box for any thing that looks like its getting hot but did not see anything. We are just looking for a direction we don't want to just start replacing parts and guessing. Thanks Tom
    Jun 2010
    463
    Re: Multi Cam MG103
    Go thru and tighten all of your electrical connection in the cabinet.
    Oct 2009
    4
    Re: Multi Cam MG103
    We already did that. I milled the table yesterday and on the home side of the plate it looks like stairs. It started good than it started stepping until it hit the hard stop on the back of the machine.
    Jun 2010
    463
    Re: Multi Cam MG103
    Give me a call. Not sure what you mean by stepping?
    Maurice Phelps
    6785481483
    Nov 2013
    152
    Re: Multi Cam MG103
    Hi
    If you have checked the electrical connections in the cabinet then the next thing to look at is the ballscrew. Is it binding ? If you are getting steps when doing a table mill operation it would suggest to me that there is something either binding or most likely loose. After the ballscrew i`d be looking at the bearing cars on the Z slides. It is odd how the table mill is leaving steps behind as once set the Z doesn`t pen down during this operation unless you are doing a multiple pass. Another possibility is that the tool is loose in the collet and slipping out. Vacuum table leaking ? Are the steps along the full X axis or intermittent ? If it`s only in a certian area along the X axis then that could be an issue with the spoilboard being not being pulled down evenly.
    Oct 2009
    4
    Re: Multi Cam MG103
    Got our machine fixed. He reloaded the firmware to the motherboard and seemed to fix our problems. But we decided to upgrade our motherboard since the tech was here. So we have an M24 motherboard if anyone is in need. Thanks
    Re: Multi Cam MG103
    I have the same machine and have tried replacing the motherboard, but it was slightly off from what my machine needs. Would like to try another M24 if you are still getting rid of it. Otherwise, I may be interested in what upgrade you used.
  1. Replies: 0
    Last Post: 12-14-2016, 02:58 AM
  2. Multi Pass multi-insane?
    By Injuhneer in forum Mach Wizards, Macros, & Addons
    Last Post: 07-13-2014, 02:33 AM
  3. Multicam MG103 connection problem
    By Romper in forum Multicam Machines
    Last Post: 06-21-2012, 08:02 PM
  4. Multi Cam MG 308
    By Pocock1 in forum Commercial CNC Wood Routers
    Last Post: 01-20-2011, 08:14 PM
