First poster from the UK here, hoping to get help with our Heidenhain unit on our Bridgeport Series 1 Interact mill.
The monitor's display is very feint now, and increasing the brightness using the knob on the front of the monitor panel hasn't improved things much.
I understand the cost of a new monitor is astronomical, in the order of £1500 GBP.
We've had a look at the graphics port's pin-out diagram and it doesn't appear to be possible to make an adaptor to allow us to use a normal PC's VGA (15-pin 3 row) monitor lead plug, and rest it on the shelf instead of using the embedded monitor (which uses 15-pin 2 row plug).
Any advice welcome, whether it be compatible monochrome monitors with details so I can trace one on ebay, or adaptor possibilities to get a normal PC monitor working with it.
Phil.
