586,740 active members*
2,592 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > need help in assembling a rotating nut
Results 1 to 9 of 9
    Aug 2013
    8
    Question need help in assembling a rotating nut
    I need help designing a strap driven nut that would stay fix but the leadscrew would translate trough the pulley driven by the strap.
    Dec 2013
    5717
    Re: need help in assembling a rotating nut
    Here is how I did one
    Built a housing
    and put roller bearings in it to fit the nut body
    Machined the pulley and put 4 drive pin holes in it that fit the nut bolt pattern
    And the way it fits together
    and the ''exploded'' assembly, note the thrust bearings on each side of the nut/pulley assembly.
    The preload on the thrust bearings is adjusted by these 4 set screws in the motor mount plate
    And the assembled view. The little roller ''car'' keeps the lead screw from rotating in use.
    I hope this gives you some ideas.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2006
    202
    Nicely done, Jim. I take it that the O.D. of the nut runs happily on the roller bearings. Did the nut body need any work to match the roller bearings?
    Dec 2013
    5717
    Quote Originally Posted by vegipete View Post
    Thank you !
    Yes, the roller bearings are happy. I was lucky in that the OD of the nut was exactly the correct diameter to fit a standard roller bearing. I don't remember the exact dimension but it was around 60mm or so.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    8
    I already thanked you buti will do it again : you are an expert. I use your photos to figure out what to do and order bearings roller, stop and leadscrew.
    Aug 2013
    8
    Quote Originally Posted by Jim Dawson View Post
    Thank you !
    i usually speak french not sure to understand "run happy". Does this mean not a press fit nor a slack fitting but just inserted in freely and turn supported all the way?
    Dec 2013
    5717
    Quote Originally Posted by jipilabont View Post
    Yes, It is U.S. slang meaning a good fit and and working well.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    8
    So a 28mm nut would run happy in a bearing of 30mm. Or may be with shims?
    Dec 2013
    5717
    No, you would want a 28mm bearing. The nut needs to fit the bearing with <0.025mm clearance. Should be a tight slip fit.
    Metric Needle Bearing
    Jim Dawson
    Sandy, Oregon, USA
  1. The methods to usee when assembling your CNC..
    By storm2313 in forum Videos
    Last Post: 09-13-2016, 02:49 PM
  2. Replies: 0
    Last Post: 03-23-2013, 08:58 PM
  3. Assembling all those pieces
    By cncadmin in forum EnRoute
    Last Post: 06-27-2012, 07:30 AM
  4. Assembling CUT2300S cnc-multitool
    By FACT in forum CNC Wire Foam Cutter Machines
    Last Post: 08-15-2011, 02:49 PM
  5. PICStep after assembling
    By guyfrom7up in forum CNC Machine Related Electronics
    Last Post: 04-07-2008, 02:43 AM
