587,040 active members*
2,902 visitors online*
    Nov 2016
    29
    Black Way Oil
    Have recently been cutting with no coolant and noticed blck streaks running down the side of my machine. The way oil is turning black during use. Is this normal?
    Sep 2006
    1738
    Re: Black Way Oil
    Have you ever taken the machine apart and cleaned it? It's just Oil mixing with "grit" which is not good, because well...grit on the ways etc leads to more wear. But you have to remember the amount of slag from casting which gets knocked off and mixed in with oil.
    -Jason
    Nov 2016
    29
    Re: Black Way Oil
    No I’ve not stripped it down and cleaned it up. Seems like a rather large undertaking. I was afraid thats what Im going to have to do.
    Jun 2004
    6618
    Re: Black Way Oil
    Oil's job is lubrication and cleaning. Dark colored oil is just a sign that it is doing it's job. I would not take that as a sign that it needs torn apart.
    Lee
  1. Black Box Vac
    By Cut to the Bone in forum Camaster
    Last Post: 11-23-2013, 08:11 PM
  2. How to tell the difference in Black ABS VS Black Delrin?
    By conceptmachinin in forum Material Machining Solutions
    Last Post: 10-17-2011, 03:43 PM
  3. 0MD black out
    By samu in forum Fanuc
    Last Post: 10-12-2010, 08:43 PM
  4. Jet Black Machine LLC
    By jetblackaircraf in forum News Announcements
    Last Post: 12-23-2008, 07:41 AM
  5. WHO Does Black PVD?
    By mabmojo in forum Material Machining Solutions
    Last Post: 09-25-2008, 03:56 PM
