586,590 active members*
2,505 visitors online*
Results 1 to 17 of 17
    Jul 2015
    46
    Random Path Pilot crashes
    I've been getting random crashes with path pilot since I've owned my machine (several years). It will just randomly crash about once a week (sometimes less) in the middle of a job. The screen freezes and the machine stops (luckily). I then need to cut power to the controller (hard reset) and reset the machine, re-find origin and re-run the program again. This has happened with both PP1.9.x and 2.0.x . I have no tool changer and it just seems to be unrelated to any specific thing the machine is doing. I thought this might be a power issue and put the controller on a UPS but it still happens. I think it might be bios related but I can't seem to access the bios? I need to check dmsg next time it crashes for clues. Anybody have any ideas?
    Nov 2012
    591
    Re: Random Path Pilot crashes
    It could be power related, but on something like the USB bus or the controller interface wires.
    Also, do you have it on network? It could be a network thing.
    It could also be some bug that slowly leaks memory, and then runs out. You might be able to check memory use over time using some system recording tool like "sar"
    Using dmesg, and checking the syslogs, seem like good things to try, too.
    Nov 2016
    151
    When you say "once a week", do you mean that PP is up and running continuously for the whole week? Or do you start it each day, and once a week during the day, it crashes?
    Feb 2008
    644
    Quote Originally Posted by jnack95 View Post
    If you get a hard crash that requires power cycle or reset to recover I would suspect problems with the PC motherboard or memory.
    Jul 2007
    1602
    When I started using PP I had problems with lockups if my compressor kicked in while I was using the jog wheel. I removed the USB extenders I was using and rerouted the cables and that solved the problem. Oh and I also installed the Tormach suppressor kit. This is in an upgraded Series 1.
    bob
    Jul 2004
    1424
    Quote Originally Posted by PCW_MESA View Post
    ...I would suspect problems with the PC motherboard or memory.
    If your PP controller is like mine, and came with only a single 1 GB RAM stick in it, then considering throwing in another stick. PP2+ and the new OS takes more memory.
    Tim
    Jul 2015
    46
    Quote Originally Posted by syscore View Post
    No, it's not continuous. I maybe use it 4 or 5 hours a day. Thanks everyone for the responses. I've upgraded the underlying Linux mint os and plugged the keyboard into a regular USB2 slot on the controller instead of the recommended USB3. It seems the crashes usually occurred when a usb key was already inserted....maybe. I've also started using a smb drive on the controller to eliminate the usb. So far so good. No crashes yet. If that doesn't work then maybe upgrading my 1 gb of RAM is next but right now I think it's either the USB system or possibly the video firmware (because X seems to freeze when the crash happens). I've had problems with both the video drivers and USB on a different Linuxcnc machine.....
    Jul 2015
    46
    Well it just crashed again. This time the machine wasn't running and the computer had been idle for abouyt 15 minutes while I was doing something else. The following are the only errors is dmesg.
    i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
    [ 1.398994] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 1.404069] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170119/psargs-363)
    [ 1.404110] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT0._GTF] (Node ffff9b98004b6898), AE_NOT_FOUND (20170119/psparse-543)
    [ 1.404163] ata1.00: ATAPI: ASUS DVD-E818AAT, 1.01, max UDMA/100
    [ 1.405632] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170119/psargs-363)
    [ 1.405669] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT0._GTF] (Node ffff9b98004b6898), AE_NOT_FOUND (20170119/psparse-543)
    [ 1.405721] ata1.00: configured for UDMA/100
    [ 1.408841] scsi 0:0:0:0: CD-ROM ASUS DVD-E818AAT 1.01 PQ: 0 ANSI: 5
    [ 1.410988] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    [ 1.411700] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170119/psargs-363)
    [ 1.411737] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT5._GTF] (Node ffff9b98004b6af0), AE_NOT_FOUND (20170119/psparse-543)
    [ 1.411942] ata6.00: ATA-8: WDC WD2500AAKX-00ERMA0, 15.01H15, max UDMA/133
    [ 1.411943] ata6.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
    [ 1.412723] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170119/psargs-363)
    [ 1.412759] ACPI Error: Method parse/execution failed [\_SB.PCI0.SAT0.SPT5._GTF] (Node ffff9b98004b6af0), AE_NOT_FOUND (20170119/psparse-543)
    [ 1.412992] ata6.00: configured for UDMA/133
    [ 1.438463] sr 0:0:0:0: [sr0] scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
    [ 1.438464] cdrom: Uniform CD-ROM driver Revision: 3.20
    Jun 2005
    656
    This on a Tormach controller or homebrew?
    Jul 2015
    46
    Quote Originally Posted by shred View Post
    Tormach controller bought several years ago..
    Aug 2014
    257
    If you search “AE_NOT_FOUND” some of the chatter includes BIOS configuration & update. The errors you posted are suggestive of ROM & HD issues.
    Also, you mentioned that you updated the Mint OS. I have done this also without any ill effects but one thing to note is that the SMB configuration file “/etc/samba/smb.conf” that Tormach has modified may get clobbered & you must edit the new file appending the following 2 statements:
    include = /home/operator/smb.conf.netbios-name
    include = /home/operator/smb.conf.share
    So this is what I would do:
    1. Check if there are any new BIOS releases for your motherboard and install the latest version.
    2. Reset the BIOS to it's default settings.
    3. Remove the DVD drive since it’s no longer needed for PathPilot 2 and to eliminate it as a potential piece of faulty hardware.
    4. Download “smartmontools” and check your hard drive.
    Note: The next 2 steps require a live version of Linux running from a USB drive.
    1. Using Memtest check that your memory is OK.
    2. Using GParted delete all of the HD partitions.
    Finally, reinstall PP and give it a go ...
    Edit: If you decide on replacing the HD get a quality SSD instead.
    Nov 2012
    591
    Those ACPI errors seem to happen during start-up (1.5 seconds into the boot) and are probably not related.
    The most common computer gremlins are bad drivers/hardware for some intermittently-used device (USB, network) or electrical noise entering either through power supply, or more commonly through things like USB or network or controller cabling.
    Feb 2008
    644
    Since this is a Tormach controller and it fails on both Pathpilot 1.9.x and 2.0.x (which have completely different drivers) , My bet would be on bad hardware...
    Jul 2015
    46
    So, I booted linux from a live CD and ran memtest for about an hour. No errors. I also reinstalled path pilot 2 and updated to the current version of 2.0.4. I've also flashed a new version of the bios. I have also determined that the ACPI errors I was getting are related to the SATA mode in the bios. Switching from AHCI to IDE eliminated them and the system seems to run fine in IDE mode (any drawbacks?). So far so good. Thanks everyone for your help.
    Jul 2015
    46
    Two weeks now and no crashes. I think it was the bios upgrade. I left the bios SATA setting on AHCI.
    Aug 2014
    257
    Good to hear. Your last post says things were working good using IDE and now you’re happy leaving it on AHCI?
    Nowadays most HD’s run in ACHI mode while IDE mode is mostly used for CDROM/DVD drives – these are separate settings in the BIOS.
    Jul 2015
    46
    Quote Originally Posted by rdsi View Post
    Putting the SATA in IDE mode got rid of the errors, but I decided they were of no consequence (i get similar ones on other linux computers) and changed it back to AHCI mode. I've been AHCI mode for the past several weeks.
  1. path pilot and fusion
    By toyshop in forum Tormach PathPilot™
    Last Post: 12-11-2017, 02:46 PM
  2. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  3. Path Pilot vs Mach 3
    By Bob La Londe in forum Tormach Personal CNC Mill
    Last Post: 10-12-2015, 07:55 PM
  4. Welcome to the Path Pilot forum!
    By kstrauss in forum Tormach PathPilot™
    Last Post: 03-13-2015, 01:41 AM
  5. Post Processor crashes with long path names
    By KSky in forum BobCad-Cam
    Last Post: 02-25-2015, 04:47 AM
