587,047 active members*
2,519 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Add Automatic Tool Changer on Partner 1?
    Jan 2010
    78
    I am trying to find information on adding an ATC to my partner 1. I am semi-new to CNC and extremely new to Milltronics machines in general. For the untrained eye, they look very similar. Is there a way to adapt an ATC from one series of Milltronic machines to another? Does any sell/manufacture ATC for Partner 1 machines as an add on?
    Any info on getting this done would be a huge step for me. Thanks.
    Feb 2018
    109
    Re: Add Automatic Tool Changer on Partner 1?
    There a few videos on youtube of home built tool changers - here is one - https://youtu.be/yj_PsRyRGM0
    Jul 2010
    548
    Sen2, Hope the machine has not yet shipped or they followed my advice on shipping the machines, from removing the control from the electrical panel and the correct way to block up the head, ( NOT on the spindle nose)
    The machine is a P1D with a C5 control, (NOT a C6) As it is a C5 control the control serial # becomes important for future repairs and or updates. look at the bottom of the control for the serial # if it is xxx-B you are good to go. if it has no '- # or it is a "-A" than there are issues with repairs and updates.
    sportybob
    Nov 2013
    128
    I happen to have a tool changer off a partner 1 sitting on the shelf. 2 of my partner ones had changer and the parts I run on them use one tool and are pretty big, so I yanked the changer. I did take measurements and notes on how and where the wires and bolts go. 1500$ plus shipping. It was working when removed.
    Quote Originally Posted by sen2two View Post
    Feb 2018
    109
    Here is the one I was originally thinking of - just could not remember where I saw it - it is right here in the Auto Tool Changer part of this forum - Ilike this one - it swings out of the way with a couple air cylinders.
    https://www.cnczone.com/forums/auto-...-cost-atc.html
  1. partner 1 tool changer problem
    By blowncoupe in forum Milltronics
    Last Post: 06-29-2015, 06:21 PM
  2. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  3. Tool Changer on a Partner I
    By bwilkinson in forum Milltronics
    Last Post: 04-19-2011, 01:55 AM
  4. Tool changer for Partner 5?
    By Brian FRF in forum Milltronics
    Last Post: 07-28-2009, 06:31 PM
  5. Partner 1 Tool Changer not rotating
    By Quadin in forum Milltronics
    Last Post: 01-15-2008, 03:23 PM
