I have mach 4 plasma with vital system arch pro screen with sheet cam the post processor that works is the mach 3 the others don't seam to work nether does the vital system one
my problem is I have en engraver in the plate marker tool I need to delite the M3 M5 command so it wont fire my torch with the spindle commands
I can disable it in mach because it take my THC off line when going from engrave to a plasma cut on the same layout im almost there
every thing works fine except torch fire win the plate marker tool using m3 m5
