Re: Source for small, cheap bt30 spindle?
It may be worth designing your own with donor parts to save build time.
To my mind, the ultimate is a universal style mill head with a quill that can be used on 'feed hold'.
With this you could do crankshaft drilling, cylinder head seats and after feed hold return to running the program, sort of a mix of manual and cnc.
The design goal should be not the machine itself, but what can be done with the machine other than cutting little square blocks with holes.
Wisdom results from foolishness!
