I did not know how to title this threat so that was the best I could do. As it says my trm is running great. I just noticed though that the power (load %) in the pendant read 0 % almost all the time. It shows a little load when the Z rapids down to the clearance plane then reads o % when its cutting. It seems to have just started doing that. Also the programmed feen rate shows in the controll but the actual feedrate always shows a little less and actualyy fluctuates a little (eg programmed 26 ipm and actual is around 20 to 24)
any thoughts
thanks
Mark
its cutting well so maybe I should just ignore these things?
