586,538 active members*
2,846 visitors online*
    Mar 2018
    Issue with my Laser cutter..
    Hi
    I'm new on here and hopefully someone form this amazing resource of knowledge/experience can shed light onto an issue with my generic 6090 chinese laser cutter?
    Basically...I'm running a Ruida RCD 6442 s(EG) controller- laser just stopped halfway through a an engraving job with laser Head staying put in position.
    No alarm sound.
    Think poss reboot- switch off then on - screen message "connecting to controller" just stays like that, no initialising.
    Check inside..
    Controls board - just Led 15 lit, Led 14 not lit.
    Green lights on X & Y drivers
    Water chillers appears ok - water flowing etc.
    Test Fire PSU - nothing
    Not sure if PSU has green LED until it fires, fan is working.
    Has been cold in the studio (UK) but I always heat the space up prior to using the machine and it had been working all day - stopped at 3.30pm.
    Wasn't sure if temp can effect controllers etc.
    Thinking if 14Led not lit.. flow sensor issue... but no alarm and seems to be working fine?
    Appreciate you're help.
    thanks
    Si
    Apr 2006
    108
    Re: Issue with my Laser cutter..
    Hello,
    You have a pretty good description of the status, but did not say anything about a blinking light.
    Look at the controller. Is one of the lights blinking. If not... Your controller is locked up.
    You might be able to reboot and install a new project. .. or new firmware.
    Ray Scott
    Rabbit Laser USA
    Aug 2018
    28
    Hi.
    You could check that the controller is properly grounded. If it does not have good grounding it produces random errors until it ends up burning.
    The Chinese try to save on everything! sometimes they do not put the wires to the ground.
    Good Luck!
    German Rothar
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
    Jan 2007
    229
    I had exactly the same problem mid job. "connecting to controller" and it fails & reboots, and repeats.
    Leds #3 & 15 are lit when it squeals.
  1. Laser cutter power issue
    By Sophia9187 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-09-2020, 03:51 PM
  2. LASER Cutter Issue
    By nickyminaj123 in forum Laser Control Software
    Last Post: 04-27-2019, 02:26 PM
  3. China first set combination of fiber laser cutter &co2 laser cutter ,in one machine
    By laserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2017, 09:00 AM
  4. K40 Laser Cutter Power Supply Issue
    By abesha4210 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2017, 10:35 PM
  5. Chinese laser cutter issue
    By ariemeir in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-04-2014, 11:24 AM
