586,845 active members*
2,547 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Pocket toolpath overcuts in some areas
    May 2011
    19
    Wen cutting a pocket that has multiple bosses and things that have to be machined around, the toolpath generated uses a common path of travel to reach all areas of the pocket. At these locations the endmill seems to overcut in the z direction leaving a path on the floor of the part.
    Anyone else have problems like this?
    Apr 2003
    3578
    Re: Pocket toolpath overcuts in some areas
    Sounds like the retract is not high enough.
    Cadcam
    May 2011
    19
    Attachment 390144
    I have attached an example of the path the cutter takes. The line that is at an angle ends up machining a little deeper. It is a common path of travel during the machining process which I cant force it to retract.
  1. Pocket toolpath with a 2000mw laser?
    By comanchesniper in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-07-2016, 12:08 PM
  2. How do you force a pocket toolpath to start at a point?
    By leftcoastlefty in forum Surfcam
    Last Post: 10-19-2014, 05:14 PM
  3. missing pocket toolpath
    By newnew005 in forum PhotoVCarve and VCarve Pro
    Last Post: 05-29-2014, 05:23 PM
  4. Mastercam neck pocket toolpath
    By jimmiethekid in forum Musical Instrument Design and Construction
    Last Post: 05-23-2010, 12:02 AM
  5. Pocket Toolpath
    By jcnewbie in forum Mastercam
    Last Post: 10-21-2009, 07:16 AM
