586,581 active members*
2,654 visitors online*
    Dec 2014
    187
    Attaching Rotary to 2017 RedSail Laser
    Just bought my second Redsail Laser, 100w 2017 model and wanting to put a Rotary attachment on it. I’ve been told there isn’t a port for this so what’s involved with getting this happening? It’s running RDWorks.
    thanks in advance
    Apr 2018
    36
    Re: Attaching Rotary to 2017 RedSail Laser
    Hi Ken,
    I'm in the middle of adding a rotary to my Redsail CNC router RS6090.
    There is a place to add the wiring if you open the cabinet. If you look on the circuit board to which the three drives connect you will
    see X Y Z...and yes a blank C axis.
    You need to buy a stepper drive. and the rotary axis.
    I also bought an aviation GX type connector to go through the cabinet wall.
    Your laser may already have a knockout on it.
    I looked at those before I went with the router, as I do mostly 3D work.
    What software did it come with for the computer to feed the machine?
    Aug 2018
    4
    I have heard that you can't add a rotary axis to these controllers, and you have to swap out the y axis. Maybe I am wrong.
  1. Replies: 5
    Last Post: 06-24-2021, 12:16 PM
  2. LightObject new ocean shipment of Laser Aug 2017
    By speedythinker in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2017, 11:25 PM
  3. Invitation of EMO Germany 2017 from 18-23 September from XT LASER
    By Jason_XTLASER in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-11-2017, 04:02 PM
  4. Attaching water tubing to laser tube
    By ByronJ in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-03-2016, 04:10 AM
  5. attaching work to rotary on DIY table
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 07-20-2007, 10:53 PM
