586,616 active members*
2,446 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Machining strategy for long, thin, plastic parts?
    Dec 2016
    10
    I'm machining sheets of thin 1/16" ABS sheet to affix to later affix to wood parts. My experience today was in making some rectangular, long strips. As I machine the first three edges, vibration can start to become an issue, but as I machine the final edge, the part starts to lift, vibrate, and interfere with the cut.
    Tabs seem to be a potential solution, but leave a bad edge, and are a lot more finicky with plastics. Are there any other machining strategies that can prevent these small parts vibrating, and coming loose?
    Apr 2009
    5516
    Quote Originally Posted by Fierra View Post
    Double stick tape
    Dec 2014
    640
    Re: Machining strategy for long, thin, plastic parts?
    Depending on how wide the stock is, you can buy some very wide painters tape and attach that to the back of the stock, attach the tape to the work surface, then glue the two together with super glue. As long as there's very little heat generated, the stock will likely not move. You won't need any tabs that way.
    Dec 2013
    5717
    That sounds like a job for a small table saw, they do rectangular strips really well. Or maybe a even a 4 inch circular saw mounted to a bench or held in a vice. Sometimes a CNC machine is not the best tool for the job.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2014
    640
    Agreed!
    Quote Originally Posted by Jim Dawson View Post
    Apr 2009
    5516
    Cutting long, thin strips may NOT be the best job for the tablesaw. There is a tendency for the sheet to lift and ride over the blade, and a tendency for one to attempt to push said sheet down, sometimes unfortunately at the wrong spot because the blade is covered. There is also a tendency for the sheet to slide under the fence, also causing a potentially dangerous situation. You'd also need at least an 80-tooth carbide blade, triple chip (TCG), preferably with zero or negative rake. And you have to feed it relatively quick to prevent the plastic from overheating and binding the blade. Using a power-saw is even more dangerous; I know at least two guys that cut themselves pretty bad cutting plastic with a power saw, which usually has a framing blade (low tooth count) installed.
    We didn't have a laminate slitter when I had my shop, so I would cut edgebanding on the tablesaw. This is a bit tricky at first if you don't know what you're doing, especially with a 4 x 10 sheet. But a piece of Masonite is placed on the saw after the fence is set, to prevent the sheet from sliding under the fence and creating a zero-clearance for the blade (preventing chipping the backer), then the sheet is uncoiled as it is pushed through. The curve on the laminate helped when pushing it against the fence.
    I still say double stick tape is the way, but you could also use 3M 77 spray adhesive; and wipe it off with naptha afterwards.
    For 1/16" plastic, you can potentially use a straightedge to score the cut line, place said line against the edge of a table, and snap it rather cleanly. I do it quite a bit with acrylic and Lexan.
  1. Thin plastic engraving?
    By kfir762 in forum Glass, Plastic and Stone
    Last Post: 01-04-2017, 02:45 AM
  2. CNCing, Long Thin Profiles.
    By dachopper in forum Australia, New Zealand Club House
    Last Post: 10-16-2016, 01:59 PM
  3. thin -plastic- materials
    By LaserMark in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2015, 12:46 PM
  4. Parting strategy for long 303 piece?
    By jbrookes in forum Haas Mills
    Last Post: 06-26-2012, 02:08 PM
  5. long thin turning
    By emmamark in forum RFQ Feedback
    Last Post: 12-07-2011, 01:50 PM
