586,988 active members*
3,841 visitors online*
    Feb 2010
    3447
    Swapping out tube for solidstate
    Hello,
    I have a universal laser (VERSA) system, and another larger system (both tubes dead). Everything else works great, but i don't want to spend the 2 grand to recharge the tubes. Would it be possible to swap in a solid state 15w diode based system such as this:
    https://www.ebay.com/itm/15W-Pulse-4...gAAOSwaWhZvJPA
    As long as i line the laser up should work right?
    Nov 2009
    47
    Re: Swapping out tube for solidstate
    I think you will find that blue laser is woefully underpowered for anything other than engraving wood and plastic.
    As a side note, would you be willing to part with/sell one of those units? I'm in the market for a co2 laser setup.
    Feb 2010
    3447
    While it's no higher power co2 laser, videos on youtube seem to show it work well enough for $200-$350 bucks. 15 watt laser apparently is only 8 watts average. No, none for sale yet.
    Sent from my SM-N910V using Tapatalk
    Nov 2010
    787
    You don`t need marking CO2? Have Synrad t100 (about 120W)
    CNC lasers, constructions, service
    Feb 2010
    3447
    Quote Originally Posted by cinematic2 View Post
    There is a 40 watt installed in it now. Cost to refill it is $2k. If it requires anything more the price shoots way up. I bought both machines for less than $1000 each. I don't cut enough stuff to justify a refill (right now), but a retrofit to solid state would be adequate enough to atleast give me functionality for cheap.
    Feb 2010
    3447
    I did find a service on ebay, user name laser-tech, who will refill laser tubes for $850. Significantly less than the quoted $2000 from synrad or universal laser systems. They have 100% feedback and many reviews, plus a real shop on the east coast. I'm going to go that route first.
  1. Swapping an axis
    By gregcoles@telko in forum CamSoft Products
    Last Post: 07-04-2013, 09:27 AM
  2. Adding a cheap solidstate Laser onto my CNC machine?
    By RomanLini in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2013, 11:42 AM
  3. Swapping vector drives
    By 6inall in forum Fadal
    Last Post: 05-31-2012, 07:49 PM
  4. Swapping M3 and M4 in Fanuc 10T???
    By Andy Fritz in forum Fanuc
    Last Post: 01-25-2010, 06:20 PM
  5. swapping bearings?????
    By the4thseal in forum DIY CNC Router Table Machines
    Last Post: 12-13-2007, 02:20 AM
