Hey folks,
Please don't take this as blasphemy... or come after me with (chair)
Looking for a tool recommendation, building a fairly typical moving gantry router. Construction is HSS steel (channel and tube). Mostly will be using it for thermoplastics and acrylic. As such, planning to use a rotozip style tool for its 'regular' cutting.
However, I know I'm going to throw some steel plate (1/2" x 6" flatbar usually) at it a few times a month - to cut simple bearing plates and adapters.
Could you guys recommend a more appropriate cutting tool for this type of work? I don't mind building another tool holder to swap tools. Ideally I'd like to be able to dry-cut if possible, but I'm pretty sure I could retrofit a liquid cooling system in relatively easily if needed...
Thoughts / recommendations?
Thanks in advance,
Andy
