586,704 active members*
2,495 visitors online*
Results 1 to 9 of 9
    Apr 2017
    77
    Mach3 MDI DRO
    does anyone know why when im telling to mach3 to move -y20 the dro read outs 19.991?
    i zero y before i asked it to move
    Re: Mach3 MDI DRO
    Could be do to your resolution, or steps/unit setting
    Apr 2017
    77
    Re: Mach3 MDI DRO
    im currently calibrating the machine and my digital indicator is saying its moving 20mm but the mdi is reading 19.991 so my steps per unit are correct but the dro isnt displaying the correct value.
    concerned when i machine the accuracy isnt going to be there.
    Jul 2005
    2415
    Re: Mach3 MDI DRO
    The resolution of a machine is the smallest distance ONE step produces. That boils down to Steps per unit. You can't make a machine have more resolution that what the steps per unit are. Mach can take fractional steps per unit but it has to average them out of a distance by applying an added step here or there to get that close. To get higher resolution you either change the gearing between the motor and linear drive elements or you get a higher resolution motor (Servo with high line count encoder)
    With no information on the motors, linear drive type or any gearing its just a general answer.
    Feb 2007
    4553
    Re: Mach3 MDI DRO
    Dfox1787,
    The thickness or width of a human hair is seven times larger than the inaccuracy you are worried about.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2017
    77
    Re: Mach3 MDI DRO
    Quote Originally Posted by jalessi View Post
    Dfox1787,
    Jeff...
    are you saying you wouldnt worry about it. it is moving the correct distance according to my dial indicator.
    Apr 2017
    77
    Re: Mach3 MDI DRO
    Quote Originally Posted by Torchhead View Post
    Hi torchhead this is a cheap china cnc 3040 machine. its driven by ballscrews and the motors are nema23 265oz 2.8a.
    i think i just need to spend more time calibrating and maybe i can get it spot on. The dial indicator is saying the axis is moving the correct distance.
    Feb 2007
    4553
    Re: Mach3 MDI DRO
    Dfox1787,
    See attached link for a little more insight into what you are experiencing:
    https://en.industryarena.com/forum/mach-3-precision-question--212578.html
    Jeff...
    Feb 2007
    4553
    Smile Re: Mach3 MDI DRO
    I have no idea what your tolerance requirements are however I myself would never worry about a .009 mm discrepancy.
    Jeff...
    Quote Originally Posted by dfox1787 View Post
  1. Mach3 Motion card XHC 5th MK4-V 4 AXIS mach3 cnc motion control breakout board
    By samnang39 in forum Automation Technology Products
    Last Post: 01-01-2017, 03:22 AM
  2. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
